Still fighting the issue of little to no power down low in the RPM range. Once RPM are higher seems to come alive. I attached a log of group 11 hopefully someone can take a look at this and help explain why this is happening. The only code I'm showing is a faulty glow plug in cylinder 4. I have ran the N75 duty cycle test in VCDS and it seems to be working correctly. Pressure tested all hoses from turbo to intake and there are no leaks. Adjusted VNT actuator so that it touches stop at 18 inHG. Any suggestions what to try?
