1 - 8 of 8 Posts
I was wondering what the cause of this is. Its nit incredibly often but when it does happen it makes my entire car jump and even sway when in park slightly.
I scanned it not too long ago with 0 errors. But it was not VAGCOM or VCDS. I'll look into that, thanks!
Discussion Starter #4
I scanned it again and came up with 0 errors. I checked out the mounts and they dont look bad. I couldnt find this snub mount though. There is a mount in the very front that has a lot of play, ive heard it be called torque something? Here's la link to what I am seeing as well.
I don't get movement like that out of mine. I have a stage 2 tune and a manual conversion on my wagen. It's been a few years since i have messed with the snub mount.
Discussion Starter #8
So, I put about 300 ml of Power Service Diesel Kleen in it and all of the jumps left after a drive from.niagara falls to hamilton. I never guessed that would've worked. It's been 4 days since I've done it and the weather has been warmer so that could be attributing to it.
1 - 8 of 8 Posts
