Looking for some help. I have a 04 Passat tdi that has run great after I changed the cam and the oil pump about 30k ago. Now it has developed a problem with shutting off randomly. It will be running fine then just shuts down and doesn’t want to restart. Planning to start with the fuel pickup and check for a stoppage anybody have any ideas? Thanks for replies
As suggested. You need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing and check systems out.
Discussion Starter · #5 ·
Sorry I didn’t post in intro. Honestly I browse several forums and wasn’t sure if I had posted here or not.
The problem seems to be with the fuel pump. I have pulled it out and started to trouble shoot it. I verified the fuel pump relay is working. I don’t have a CEL on but I will check for any codes.
