Have a '03 Jetta with a ECU that doesn't want to read the ESS consistently. Replaced the ESS and checked the wiring, still drops the ESS once in a while especially when hot. Next suggestion was the ECU, so I picked up a used ECU without bothering to read up on SKCs, IMMO-3 and what one has to do to get a used ECU to work in an 03 Jetta. So now looking for the best (i.e. least expensive) option for reprogramming a used ECU to work in my Jetta.
Did you check out the immo faq? That's probably a good place to start, I can't remember the name of the software but I think there's something that can be used to retrieve the info so you can reprogram it, I'm not 100% though:)
welcometomyturbodies
Just remembered, vag tacho I think it is but failing that I think it'd be a tuner job.
You can google it VAG TACHO or search on here for that?
VAG TACHO USB Manual
