Would it be OK to do a diesel purge as a prime for new fuel filter?
Discussion in 'VW Mk3 Jetta, Passat TDI and other/older diesels' started by fleck, Jul 12, 2016.
  1. fleck
    fleck New Member
    May 23, 2016
    12
    98 Jetta tdi
    Alaska
    Just wondering (if replacing fuel filter anyway) could I empty a bottle of Diesel Purge or similar into new fuel filter, completely remove and replace old fuel filter with new fuel filter and drive as opposed to hanging a bottle separate from filter and idling.
  2. crsmp5
    crsmp5 Well-Known Member
    Feb 14, 2012
    1,254
    85 kubvan
    i zip tie it to the upper ac line, new rubber hoses into the can and take for a 5 min drive...
    you may as well dump it in the tank that way.. the fuel return flows more fluid then the car uses... so... you will just push it all into the tankas it sucks fuel from the tank...
    fleck likes this.
  3. fleck
    fleck New Member
    May 23, 2016
    12
    98 Jetta tdi
    Alaska
    That's what I was wondering, thanks. (If it is OK to move/drive the vehicle on straight Diesel Purge)
  4. xeno555
    xeno555 Well-Known Member
    Dec 12, 2011
    1,636
    2012 TDI Tech Package 6mt
    Mile High
    Yes, it is like +98% diesel.
    fleck likes this.
