Wheel bearing replacement
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by Unobogus, Mar 14, 2012.
  1. Unobogus
    Unobogus New Member
    Feb 7, 2012
    7
    2004 VW Jetta TDI
    Hello, I'm new to the site and I've been on here searching on how to replace my front wheel bearings on my MK4 Jetta TDI. I don't have the pullers or a press, so hopefully someone know how to do it without those tools. I can't find anything, can someone lead me in the right direction?
    Thanks for any help.
  2. YMZ
    YMZ Super Moderator
    Sep 22, 2010
    2,096
    Jetta 2003, Golf 2001
    Sorry, but I don't know of any method for replacing them that doesn't involve some tools that aren't normally in the possession of the average backyard mechanic.
    The easiest way to get it done would be to remove the steering knuckle (mark the bottom bolts with paint so that you can replace the ball joint in exactly the same spot) and take it to a shop - some Napa stores are able to press out the bearing and press in the new one...
    Yuri
    PS: make sure to get a new nut (some cars use bolts) for the end of the driveshaft... as well, be sure never to let the car's weight rest on the wheel while it's turning unless that end nut (bolt) is properly torqued... that's the easiest way to ruin a new bearing...
  3. Unobogus
    Unobogus New Member
    Feb 7, 2012
    7
    2004 VW Jetta TDI
    No problem. I realize that I need some tools, I just wondered if I could get them out without an actual bearing puller, maybe with a punch, socket, chisel? Also, could I press the new ones back in with a vise or clamp? Not an actual press. Local mechanic wants $425 to do the front bearings and I don't want to spend that much.
    Thanks for your help.
  4. YMZ
    YMZ Super Moderator
    Sep 22, 2010
    2,096
    Both front bearings? Very unusual for the two to need replacing at the same time... (unless one guesses wrong and replaces the one that was good...)
    Check to see how much local shops (Napa, PepBoyz??) would charge if you bring in the knuckle...
    Yuri
    PS: before someone chimes in saying bearings should be replaced in pairs... over decades of VW ownership, I've never had more than one bearing go within 2 years of another... and we drive a LOT... current car: LF replaced at 120,891 miles... RF at 277,740 miles... original rear bearings still good at 457,000 miles...
  5. Frank M
    Frank M Member
    Aug 15, 2011
    214
    2000 NB
    ventectomy
    you can actually replace the bearing without a press or puller if you get creative.
    Take off the knuckle as mentioned.
    Drive (hammer) the hub out using an old socket that will be a little smaller than the hub itself.
    Remove the E ring.
    Hammer the outer race out of the knuckle using a cold chisel on the ridge in the center of the ridge, be patient. After you get the race out you can cut a slice through it with a cutoff disk. This will make it slightly smaller than original and can be used to remove future races.
    Cut the inner race off the hub using a cutoff disk, a dremel will work, be patient.
    Install the new bearing by using the old outer race. hammer it in, never put pressure on the inner bearing race.
    Install the E-ring.
    Put the hub on a block of wood with the bearing end facing up.
    Put the knuckle over the hub and use the small socket that you used earlier to hammer the inner race onto the hub. Bottom it out completely.
    The idea is to not force the hub into the bearing without support to the opposite end inner race.
    This is crude way to work but it can be done without special pullers, press etc.
    A good chance you may ruin your bearing the first time you try it. Patience has to be learned sometimes.
    Buy a quality bearing or else you will be doing it again soon.
    If you want aftermarket get a Timken from Autozone or other well know name from a vendor.
    Clarke likes this.
  6. shuswap
    shuswap Member
    Dec 12, 2010
    186
    2005 Golf TDI auto
    I was all set to change both when the mechanic at the German local shop(1st time I've had someone touch a car or bike of mine in 25 years) told me to just do the one side, which I did...$180.
    Isn't the part available with the bearing mounted onto the hub, saving much of the grief I was trying to avoid? I think that's what the mech did to mine....50k ago:)
  7. Unobogus
    Unobogus New Member
    Feb 7, 2012
    7
    2004 VW Jetta TDI
    Thanks for all of the information, I do appreciate it.
  8. Frank M
    Frank M Member
    Aug 15, 2011
    214
    2000 NB
    ventectomy
    The $180 sounds fair.
    The bearing has to be pressed into the knuckle with force applied to the outer race only.
    I can not imagine it pressed onto the hub then into the knuckle and how would the E-ring be installed with the hub blocking it.
    Additionally the cost of the hub is lots more on the parts cost and unneeded as well.
    Any ad showing it pressed as an assembly is either for another application or trick photography in order to sell the assembly, implying an easy installation.
  9. YMZ
    YMZ Super Moderator
    Sep 22, 2010
    2,096
    Could you be thinking of the rear bearings?
    Yup... I agree with Frank M that the $180 sounds fair...
    BTW: Frank: nice outline of the "old-school" way of doing this...
    Yuri
  10. shuswap
    shuswap Member
    Dec 12, 2010
    186
    2005 Golf TDI auto
    No, front bearing. It's been a while, but I thought it was necessary to cut the old bearing off and press the new one on......or buy the hub with bearing already pressed. Jeeez...when I read that....somewhere...I decided it wasn't worth the effort to save about $95.
    I may have been wrong about how that piece is assembled:eek:
  11. farmerben
    farmerben New Member
    Oct 16, 2013
    7
    2003 Jetta wagon
    Resurrecting this old thread as I have just done my bearings and am in the process of torquing the hub nut to spec. Noticed that on the passenger side the nut runs well onto the stub, but on the driver side the stub is essentially flush with the outer face of the nut. Should they be the same or very similar. Any thoughts on why the two would be different.
    Thanks Ben
  12. npottage
    npottage New Member
    Feb 4, 2016
    4
    05 jetta tdi (early)
    vancouver island
    hey all!!
    just getting ready to tackle this... bought the hub assembly and as it turns out the one i ordered bolts on. Well long story short I have an early 05 jetta and the hub must be for a later one because when I got the wheel off and started looking for the hub mounting bolts................ well there wasnt any! A press in and out show for sure. kinda sucks cause I live 4 hours drive away from the parts store.
    I have gleaned tips and part numbers etc of of some of these forums and am wondering if anyone has any "must avoid" type tips?
    I have lots of experience lately replacing wheel bearings but they have all been bolt on hubs (too many old vehicles)
    thanks
    Nat
  13. crsmp5
    crsmp5 Well-Known Member
    Feb 14, 2012
    1,346
    85 kubvan
    bolt on is mk5... 05 is a split year...
    requires press or the bearing tool.. you cannot hammer this stuff out... ive seen 50 ton presses struggle..
  14. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,792
    Scotland
    PP764's, turbo and mapping
    I've rarely seen them that bad, only when it's been neglected so long it's welded itself in lol
    I hammer them out all the time, just need the right size hammer and a steady surface to support the spindle.
    I wouldn't hammer them in though, best with a press or if stuck a big vice also works.
  15. crsmp5
    Feb 14, 2012
    1,346
    85 kubvan
    i saw a broke a 200tom press at a machine shop i took a subaru rear spindel too to press the cv joint out.. im glad they broke it... and i gave up on 50 ton one first... they too on my list of no i will not touch them cars.. it needed rear wheel bearings.. and could not budge the axle on eirther rear.. the fronts took massive effort too.. but it broke the 200 ton press.. everytime i deal with one it turns into a lost cause... by the end of a few years.. think i hate new vw or any audi.. subaru is right there with audi
  16. Greasyburglar
    Greasyburglar New Member
    Apr 21, 2016
    VW Jetta TDI 2005 (early)
    Monroe County Michigan
    I'm not sure if I need to start a new thread as my question refers to rear wheel bearings.
    I disassembled far enough to see the ball bearings and was surprised that I could see them. There was little or no grease. This is the point where I realized I'd need assistance to remove the bearing. I was wondering if this is unusual at 110K miles (lack of grease). The only complaint has been from passengers hearing "bearing noise". I had assumed it was tire noise. With the caliper out of the way, the hub spins freely without excessive play or noise.
    I was wondering if adding grease with a grease needle would be a possibility. Also I'm not sure if there are two rows of ball bearings and if so whether the grease would be able to reach the inner row. This much I think I could accomplish myself, and considering the only complaint is noise (which we have argued over) adding grease could only improve the situation... right?
  17. crsmp5
    Feb 14, 2012
    1,346
    85 kubvan
    rears are not like the older tapered stuff... its more like a front.. removing it tends to ruin it as the inner race usually requires a gear puller to get it off the stub axle
  18. Seatman
    Jul 9, 2010
    5,792
    Scotland
    It's knackered, no amount of grease will help, the original grease escapes, dries out etc but then the bearings take a hit so they're not as round as they look any more and of course they now make a noise. Only fix is a new hub as the bearing is not replaceable on its own.
  19. Greasyburglar
    Apr 21, 2016
    AArgh! No easy way out! Attacking it today. Thanks crsmp5 and Seatman.
  20. npottage
    npottage New Member
    Feb 4, 2016
    4
    vancouver island
    Well it didnt go too badly.
    about 2.5 hours start to finish out in the driveway. had to go old school with persuading the old bearing out with a socket and mallet. the knuckle was suprisingly easy to separate from the strut.
    To remove the inner race I put the hub in a vice then poked a small cold chisel through a space in the abs sensor ring, a few well placed taps made enough space to put a 3 jaw puller on and off it came no swearing required.
    I used the old bearing to tease the new one back into place to avoid damaging the seal with a socket.
    the most frustrating part of the whole exercise was trying to position the 3 bolts which hold the bottom ball joint of the knuckle to the car, with a wee bit of strut pressure holding the knuckle down slightly I had to get creative with a jack and cinch strap.
    while under the car I noticed one differential bearing is gone so that is the next undertaking. (kinda nervous but Im not going to let fear and common sense hold me back)
    Oldaccord likes this.
