Weird oil leak on the back of alh engine
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by eddielee, May 20, 2013.
  1. eddielee
    eddielee Member
    May 10, 2013
    55
    Jetta/2001
    Hey I am trying to diagnose an oil leak on the back of the engine, it is not the turbo, valve cover, and doesn't appear to be head gasket.
    I cleaned it all up and wiped down to as clean as possible, no significant oil present, then started it up and let it present again.
    The only place I can see it coming from is the engine mount on the pulley side of the engine.
    it runs down the back side then down the block.
    I cannot think of something that should leak here. There is no oil in the timing cover or on the belt as I can see.
    I have recently used a engine mount bracket repair kit on it purchased from idparts.
    Any ideas of what might leak??????
    23,854
    EGR diaphragm weep hole? There are also some vac hoses around there.
  3. Frank M
    Frank M Member
    Aug 15, 2011
    214
    2000 NB
    ventectomy
    can also be the cam seal. they leak out the back of the plastic cover only, sometimes.
  4. eddielee
    eddielee Member
    May 10, 2013
    55
    Jetta/2001
    Thanks Guys
    I am going to replace the Cam seals and look for faulty oil plugs on the engine when I am in it.
    It is not the EGR as there is no oil any where around the top of engine, just presenting from the top of the engine bracket.
