Water pump bolts 2003 Jetta TDI
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by Mark Sankey, Jan 29, 2012.
  1. Mark Sankey
    Mark Sankey New Member
    Jan 29, 2012
    vw jetta 2003
    I have a 2003 Jetta TDI and I'm doing the timing belt and was wondering if it is ok to use never sieze on the water pump bolts.Our first belt change was done at the dealer and the bolts came out ok and I don't think they used anything. Thanks
    23,900
    I wouldn't. The bolts don't have a history of seizing up.
  3. almir
    almir Member
    Feb 6, 2011
    669
    2005 jetta tdi gls 1.9
    Chicago
    tdi's vibrate you don't want them to become lose easy. I personally used red tread lock when I did my TB. After 80,000 miles of vibration they will come out easy if not I can heat them with a torch for 3-4 seconds and everything is back to normal.
  4. YMZ
    YMZ Super Moderator
    Sep 22, 2010
    2,111
    Jetta 2003, Golf 2001
    I wouldn't use red LocTite there... blue's fine... yes, you definitely don't want those bolts backing out... ask me how I know...
    Yuri
  5. almir
    almir Member
    Feb 6, 2011
    669
    Chicago
    I can assume you had problem with the TB tensioner bolt backing out from vibration and breaking.
  6. YMZ
    YMZ Super Moderator
    Sep 22, 2010
    2,111
    I thought we're talking about water pump bolts... there are no TB tensioner bolts... studs and lock-nuts... Yes, I've had a water pump bolt back out... needless to say I got to practice my timing belt replacement routine earlier than expected...
    Yuri
