VW_Caddy_1.9TDI_black_smoke
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by Eugen, Nov 18, 2010.
  1. Eugen
    Eugen New Member
    Nov 17, 2010
    VW Caddy 1.9 TDI
    Hi,
    I have a 2006 VW Caddy with 1.9TDI (BLS type) - 120000 miles. Very noise engine in the cam shaft area and a lot of black smoke when I push the acceleration pedal.
    Could be a valve, cam shaft or turbine ?.
    Any clue will be appreciated.
    Thanks.
    23,902
    Welcome! Post moved to the mk5 technical section.
    I'm not familiar with that engine but if you believe it to be a camshaft wear issue, take a look at the writeup in the FAQ section on inspecting camshaft wear on PD TDI engines.
    welcometomyturbodies
  3. vw709
    vw709 New Member
    Jan 1, 2008
    94
    Yes, if the turbo seal is bad and blowing oil out the exhaust it will cause lots of smoke.
  4. Nikomas
    Nikomas New Member
    Apr 21, 2011
    VW Caddy 1.9TDI(BLS)/2007
    Likely clogged DPF (Diesel Particle Filter). I recommend that you use a car with higher engine revolutions. I also had black smoke until I drove at high engine speeds. Now there is no smoke.
  5. samuel
    samuel New Member
    Nov 11, 2011
    caddy
    you may have camshaft wear i have the same car same problem sa ai o zi buna!
