Vibration damper and v-belt?
Discussion in 'VW Mk3 Jetta, Passat TDI and other/older diesels' started by Bearcharlemagne, Apr 10, 2012.
  1. Bearcharlemagne
    Bearcharlemagne New Member
    Mar 28, 2011
    4
    1996 Passat
    So here's my dilemma. I've got a '97 B4 passat TDI, and when it is cold, it chirps like you're in the rainforest. So I've slimmed it down to being the dampener pulley / crank pulley / all the other 100 names it has. This is the pulley that the v-belt pulley sits on top of.
    I've got a new crank pulley, but it does not have a v-belt pulley mounted on it. Is the v-belt pulley removable from the original crank pulley, or do I need to buy an all in one part. I can't seem to figure out how the two are attached.
    Thanks,
    Ben
  2. YMZ
    YMZ Super Moderator
    Sep 22, 2010
    2,111
    Jetta 2003, Golf 2001
    There are 2 parts... the crankshaft pulley (sprocket, actually) has the teeth for the timing belt... it's attached with one bolt to the front of the crankshaft - and on your model, it's known for becoming loose... (keep in mind that bolt is a single-use fastener that must be replaced each time it's loosened... As well, if not kept tight, you can wear out the crankshaft...) The Harmonic Balancer (also called Vibration Damper), which is the pulley for the accessory belt, attaches to the crankshaft sprocket with 4 bolts... On your model it's of a 2 part design, and the rubber is known for wearing out, hence the chirping... You need to replace the harmonic balancer...
    Yuri
  3. chittychittybangbang
    23,900
