VCDS Telephone fault codes
Discussion in 'Ross Tech VCDS forum' started by vwottawa, Jul 13, 2011.
  1. vwottawa
    vwottawa Member
    May 11, 2011
    72
    2011 Jetta Sedan TDI DSG Highline
    Ottawa
    VCDS Avail.
    Hi,
    Just got my VCDS micro-Can cable last night and made a few modifications to the 09-Cent-Elect module.
    I did an AutoScan before doing anything and got no fault codes.
    I then changed a few things like the comfort windows, number of flashes for the tap turn signals, turn off beep when locking, turn off auto locking after 15 km/h.
    I then did a second auto scan and got these fault codes below. Is this normal to get a fault code even though I did not even start the car and only changed a few items unrelated to the phone? Could this be a false code? or Could it be a code that was masked and by changing a few things came to light?
    01-Engine -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    2B-Steer. Col. Lock -- Status: OK 0000
    56-Radio -- Status: OK 0000
    ... snip....
    Address 77: Telephone (J412) Labels: 7P6-035-730.clb
    Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
    Component: TELEFON H05 0440
    Revision: 1B001001 Serial number: 00007668640546
    Coding: 0A00000000010100
    Shop #: WSC 01383 790 50316
    ASAM Dataset: UHVNA A01007
    ROD: UHVNA_VW36.rod
    VCID: 3245CF61D4BF
    2 Faults Found:
    9457425 - Negative output audio channel for speech/telephone
    B104F 11 [000] - Short to Ground
    Freeze Frame:
    Fault Status: 00000000
    Fault Priority: 0
    Fault Frequency: 78
    Reset counter: 0
    Mileage: 0 km
    Date: 2000.00.00
    Time: 00:00:00
    9457169 - Positive output audio channel for speech/telephone
    B104E 11 [000] - Short to Ground
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 78
    Reset counter: 0
    Mileage: 0 km
    Date: 2000.00.00
    Time: 00:00:00
  2. Keithuk
    6,813
  3. vwottawa
    vwottawa Member
    May 11, 2011
    72
    Ottawa
    VCDS Avail.
    So I did another scan again last night and this time no faults.
    I am just going to ignore them until something stops working.
    Thx for your response Keith.
