VAG-COM sotware versions
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by triscal, May 27, 2012.
  1. triscal
    triscal New Member
    May 25, 2012
    17
    2003 VW Jetta TDI
    Hi all.
    I purchased VAG-COM years ago and now I have two VW's again and they are both TDI's.
    The question is there are 4 installation files packaged with the software.
    They are as follows : 1. VAG-COM-RELEASE-5124U
    2. " -6073U
    3. " -7041-0422
    4. " -7041-1016
    So which one is the correct one too use on a 2003 Jetta TDI and what are the differences between them.(If any).
    Thanks
  2. Keithuk
    7,073
    There have been many versions of VAG-COM\VCDS just read the Revision History, Major Releases: and see which one is compatible with your vehicle. VAG-COM was changed to VCDS in 2008.
    Do you have any version as you can google it and download the older versions?
    VCDS Compatibility Charts
