USB on Fender Audio System
Discussion in '2012-2016 VW Passat TDI forum' started by jsclarke, Oct 3, 2011.
  1. jsclarke
    jsclarke New Member
    Oct 3, 2011
    Infiniti M35
    I just checked the 1000 question section- but am hoping some of you owners can elaborate on the Fender Audio system. Can you play MP3's, from a USB disk on key, via the Fender audio? It appears you need a cable to change the MDI to do this (instead of an ipod). This is actually critical for me- I regularly record internet radio and play it in the car. Thanks everyone... John
  2. MyAvocation
    MyAvocation Member
    Aug 6, 2011
    254
    Jetta TDI 2006.5
    Just use the SD slot.
  3. Rick DD
    Rick DD New Member
    Sep 12, 2011
    2012 JSW
    Just get a MDI to usb cable to replace the ipod one, i use a 360g hard drive that i partitioned down to 100g holds everything i need , i also use a 32g thumb drive , sd card works ok but seems to have a folder and total no. of files limit, the usb does not, i ordered my cable from ebay $20.00
  4. waterboy719
    waterboy719 New Member
    Oct 1, 2011
    7
    2012 Passat TDI SEL
    There is also the round input device ( sorry not sure what it is called ) by the ipod cable you can plug into..... Plug would look like a mini ear phone jack or old mic jack. I would assume earphone on your phone to this port in the car.
    Hope this helps
