unusual squeal/ringing under accel
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by highly, Mar 6, 2011.
  1. highly
    highly New Member
    Mar 6, 2011
    4
    2000 TDI ALH
    OK, having a very unusual sound in a MK4 Golf TDi ALH. It only happens under moderate (normal) acceleration and only in 1st or second gear. It starts at 2800 and continues to 3800 RPM. It sounds somewhat like a brake squeal in nature, but more like when you make a crystal wine glass 'ring' by rubbing the rim much like a pulley ringing.
    I've checked things out with VagCom and found nothing. I've lifted the car up and put it in gear accelerating through the RPM range and nothing. Pulled the wheels and checked all associated moving parts for unusual wear. It never happens in any other gears or at any other RPM ranges. Brakes are good, no obvious play in the front wheel bearings. Axles/boots are all good. I visually inspected all drivetrain parts and see no rubbing or indication of chafing anywhere. No apparent soot from EGR pipes. Some oil in the boost pipes, but just a coating.
    The sound comes from the front of the car and seems like it's from the driver side. Recent changes to the car in the last 10k miles are a new 100k timing belt, all timing pulleys, water pump, serpentine belt, and the car was chipped w/ new nozzles. Timing belt and path looks clean and VCDS tdi fuel timing checker is just a little advanced. Checked the EGR system and there are no sooty leaks indicating a problem there.
    Troubleshooting today, I found the VNT actuator sticking. Removed, cleaned, verified, and replaced. Pulled the serp belt and verified correct function of the clutched alternator pulley. Operates properly, but replaced anyway because I don't know how old it is. New one was stiffer in freewheel direction. Did vacuum testing and found that the small line from the vac pump at the valve/tee does not hold vacuum (removed small line from the tee, applied mityvac to line). Troubleshooting indicates that the N75 valve allows air to pass when mityvac is on the top nipple, car turned off. Everything else on the circuit holds vac. This doesn't seem right. Should it do that?
    I'm stumped on the noise. Took a 12' piece of silicone tubing and stuck it in the engine bay near numerous items with the other end stuck in my ear while driving to find the ring. No luck so far. Tried transmission, vac pump, Brake booster, N75 valve, and power steering pulley. Nothing. I'll continue when the wife is done using the car later today.
    Anyone with ideas?
    23,757
    I haven't taken it apart but your N75 sounds like it's working.
    No clue on noise. It could be some load is causing noise in the transmission or turbo. You already ruled out brake, alt pulley, and belt noise.
  3. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,744
    Scotland
    PP764's, turbo and mapping
    welcometomyturbodies
    Is it possible to get a recording of the noise at all?
  4. Fluid
    Fluid New Member
    Jan 17, 2008
    482
    I'd say it was an intake resonance but that's not a complaint unless you modified the intake. You already checked the EGR pipes for soot deposits but also check the intake hoses for leaks. Do you have a rust hole in the exhaust that's whistling?
    Maybe you have a bad pulley on the timing belt? You said the timing belt was changed in the last 10k, maybe you have a defective part. Where did you get the parts?
    It's not the chip or nozzles.
  5. bbogdanmircea
    bbogdanmircea New Member
    Jul 14, 2010
    9
    VW Golf MK4 Variant 1.9 TDI 101 HP
    Hello.
    I have a similar problem and still couldn't find a fix for it.
    The sound that I hear is like a ringing or vibration.
    I thought it was from the alternator pulley so I changed and and the alternator spring tensioner too.
    What I observed is that after I changed the spring tensioner the sound seems to apper in a broader rpm range. So I deducted that it some component on the accesories belt that has a problem.
    I hear this sound in any gear, when the engine is from 2000 to about 2500 rpm so at maximum engine torque.
    It's more like a vibration.
    I suspect the alternator rollers maybe or the powersteering pump rollers...
    I'm not sure at all, many mechanics said different things, already invested in the alternator pulley and tensioner for nothing...
    I will try to remove the accesories belt and run the car whitout it to see for sure if the noise is from the accesories belt. If it still appers then it may be from the timing belt or something else.
  6. almir
    almir Member
    Feb 6, 2011
    664
    2005 jetta tdi gls 1.9
    Chicago
    if you still have TB cover removed then check your TB idler pulley. Many people complain about their idler pulley bolt breaking for some reason. Maybe your is giving you some signs.
  7. k4u2luz2
    k4u2luz2 New Member
    Oct 24, 2011
    2006 VW Jetta MKV
    I have the exact same problem in my 2006 and it is killing me. I have checked all the things you have all mentioned and still can't diagnose. The only thing I can think of is, it must be the bearing on the impeller shaft of the turbo. Anyone...open for more ideas.
    Keith
  8. highly
    highly New Member
    Mar 6, 2011
    4
    2000 TDI ALH
    My case turned out to be an exhaust leak (of all things!). The corrugated hard pipe on the EGR was cracked. When the pipe finally split the squeal became a more recognizable sound and I was able to locate it. Even if it seems intact, pull it off and check it. Bet it comes out in more than one piece!
    Hope that helps!
    -Todd
  9. mountain lion
    mountain lion New Member
    Jan 4, 2011
    2004 Jetta TDI
    Stock
    Hi - I have this exact same sound under the same conditions on my 2004 PD (110k miles). Before this loud squeal, a feint ticking developed that sounds like a rock in the tire tread or metal tapping, but I can only hear it under load / moderate throttle. My first thought was exhaust leak somewhere based on when it would happen, but I had no way to locate it. The tick is still actually there, but now I have the squeal to go along with it.
    Assuming I have the same issue, would EGR block off plates effectively stop the noises and the leak? I have a tune so CEL's will not be an issue. I'd prefer to leave everything stock, but don't want to buy a whole new egr setup if the block off is easier. Thanks
  10. highly
    highly New Member
    Mar 6, 2011
    4
    2000 TDI ALH
    I'd say that if the EGR blockoff doesn't fix it then you've effectively diagnosed that the hardline isn't the problem. Alternately you could remove the hardline and when it falls apart in your hand you will know that was the culprit and it's time to buy blockoff plates.
  11. SilveR316
    SilveR316 New Member
    Jun 9, 2013
    2000 VW Golf TDI
    Sorry to resurrect this thread, but did you ever figure out this issue? I have the exact same problem, down to the ticking before hand and now the screeching noise.
  12. highly
    highly New Member
    Mar 6, 2011
    4
    2000 TDI ALH
    Have you checked the EGR recirc pipes? And by checked I mean removed them to verify they are intact?
  13. SilveR316
    Jun 9, 2013
    2000 VW Golf TDI
    My EGR has been removed completely for years now. There are block off plates in place of where the EGR assembly attached.
  14. mountain lion
    Jan 4, 2011
    2004 Jetta TDI
    Stock
    It was my lower EGR pipe that was cracked at the ribbing. I ended up blocking it off. The sound like this is usually s an exhaust leak somewhere though. With EGR out, not sure where it could be for you. Exhaust manifold, something near the turbo? Hard to say till you get down there. Maybe look for exhaust/suit build up concentrated in a strange spot where it'd be leaking. Soapy water is also a good test...
