Turbo shuts down
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by vwalex, Mar 6, 2012.
  1. vwalex
    vwalex New Member
    Mar 4, 2012
    Jetta/2003 Beatle/2005
    I have a 2003 Jetta TDI w/ 118K. Lost the first turbo under warranty @ 40K (2005). The second lasted another three years before it presented the current problem.
    When I start the car from any engine off condition the turbo will not engage until I bring the engine up 2800 RPM. From that point on it runs great until I shut down the engine. The time that the engine has been shut down, seconds or days, does not affect the condition nor does the temperature of the engine. Almost got killed when I pulled out into traffic forgetting that I would have no acceleration for the 20 odd seconds it takes for the turbo to engage. Time to find and fix the problem.
    Having reviewed the turbo section in the FAQ, I plan to remove and test the actuator, but I would think that a bad actuator or turbo would continue to cause problems after the initial run up to 2800 RPM. But it runs great so long as I don't shut it off.
    Ideas?
    23,891
    It could be sticking, when it breaks free the vanes move and you get the surge of power. No way to guess until you test it for yourself. Don't forget to check for codes and read low power and limp mode articles in FAQ.
  3. vwalex
    vwalex New Member
    Mar 4, 2012
    Thanks for the tips.
