Tiptronic transmisson torque converter not locking up in overdrive
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by boverwagon, Jan 18, 2012.
  1. boverwagon
    boverwagon New Member
    Jan 18, 2012
    Passat TDI Wagon/2005
    Experiencing higher than usual RPM's in 4th gear on level road. Appears the torque converter is not locking up. Is there an electronic A/T controller going bad? I've had problems in the past with Honda automatics. They were notorious for failed electronic controllers. I read some other blogs stating the torque converter seal may be bad, causing higher RPM's. My fuel mileage is significantly decreased. Any info would be greatly appreciated!!!
    23,902
    There have been a few cases of bad torque converters, trans computer is under pass seat, if it gets wet it can also be damaged.
