Timing Belt Tensioner stays in place without nut
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by oldman, Aug 11, 2012.
  1. oldman
    oldman New Member
    Jun 18, 2012
    4
    2006 vw jetta tdi
    Hi, I am in the process of replacing the timing belt on my 2006 Jetta TDI (BRM) for the first time. I have everything in place but noticed the belt tensioner will stay at the proper tension (not turning the engine over) with the nut removed. I think the old tensioner did the same thing. I would like to know if this is normal or if it is some thing I should be concerned about. If it is a concern I would like to know what to check. The tensioner locking tab is in the slot as it should be and everything else looks right to me. Help would be appreciated.
    23,900
    Normal enough, it can move slightly if you touch it though and always counterhold when giving it final torque or else it can rotate with the nut. Remember the final 1/8 turn too.
  3. oldman
    oldman New Member
    Jun 18, 2012
    4
    2006 vw jetta tdi
    Thank you for your response. I thought the tensioner would try to back off once the allen wrench was removed but am glad things are ok.
