TDI 1.9 ALH Injector Pump Install
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by stump, Jul 3, 2012.
  1. stump
    stump New Member
    Jul 3, 2012
    jetta tdi 1999
    I bought a rebuilt injector pump and have a problem with setting the timing. Is there a timing mark on the pump when you put a new woodruff key on the front of the pump? How does the connector for the gear align to the pump? And what size woodruff key do I need?
  2. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,792
    Scotland
    PP764's, turbo and mapping
    Do you mean there's nothing on the end? Just a shaft and no pulley?
  3. crsmp5
    crsmp5 Well-Known Member
    Feb 14, 2012
    1,349
    85 kubvan
    correct there is NO KEY on a alh... the 3 bolt hub is a press fit...
  4. YMZ
    YMZ Super Moderator
    Sep 22, 2010
    2,096
    Jetta 2003, Golf 2001
    It's a tapered fit... extremely tight...
    The "rebuilt" pump (by any chance did you buy it from a seller in North Carolina???) should have had the hub already installed and timed... you'll need to send the pump to a Bosch shop to have it properly timed unless you're a fan of Roulette...
    Good luck,
    Yuri
  5. crsmp5
    Feb 14, 2012
    1,349
    85 kubvan
    your correct... id also consider that a "press fit" as it requires the nut to tighten it soo much it does not slip.. much like a cam gear... but even more so on the pump it seems...
    if you wanna "prey" method it... the key way slot in the pump should be in the 10-11 o'clock position... imagine a straight line thru the pump.. the #1 injector fitting off the pump it should be dead nuts in line with...
    but yes.. the 3 bolt hub is not supposed to be removed.. when i did my disco pump on my ahu i had to remove its "hub" different then vw anyways.. most put a alh pully set up on it... i had my ahu pully modded so i could reuse the key.. and also prevented more bs of finding a later set up and thinning it out machine work to fit the newer pully on a ahu.. this was for a mechanical tdi project in my kubvan..
