Stuff that blocked the heater core.
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by mikeme, Oct 6, 2014.
  1. mikeme
    mikeme Active Member
    Jan 29, 2013
    641
    2009 JSW TDI 205,000 miles
    Northern Virginia (dead in dealer parking lot since 15 august 2017)
    [​IMG]
    This was flushed out of a heater core on a 2009 TDI Jetta in Houston.
    any idea what this stuff is?
  2. chudzikb
    chudzikb Member
    Feb 3, 2011
    434
    05.5 Jetta, 03 2 door Golf
    Lancaster PA
    That is bizarre. Some tech did not like you for some reason and dumped something in your car?
  3. mikeme
    Jan 29, 2013
    641
    Not my car. an internet friend with the same car I provided some heater performance comparison. (why he needs heat in Houston, I am not sure, but I guess if it is in the car it should work.) the coolant loop that feeds the heater also cools the EGR, I am pretty sure, so it is good to have it cleaned out even if one did not want heat.
  4. chittychittybangbang
    23,900
    Looks like sand. Doesn't look like rust but you can test it with a magnet.
  5. chad ambrosius
    chad ambrosius New Member
    Feb 7, 2016
    vw jetta tdi sportwagen 2009
    seattle, wa
    mine on my 2009 jetta tdi sportwagen (cbea engine) had a very similar substance that I discovered thanks to "no heat." I'm about to do my timing belt change and heater core replacement, so I'm curious what else I'll find.
  6. mikeme
    Jan 29, 2013
    641
    You may want to take some time and flush out the system with a water hose.
    a couple adapters will let you push water through the three paths involved to get as much of the granular stuff out as you can.
    [​IMG]
