steering rack repacement tdi alh
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by johnmarkoe, May 24, 2012.
  1. johnmarkoe
    johnmarkoe New Member
    Mar 9, 2010
    4
    2001 jetta tdi
    waiting for pp357
    Removing steering rack everything is apart but the part where the steering weel connects am I sopsed to take thethe pin out? Any help or tips whould be helpfull thanks. trying to get a jump on it before parts arrive.:bowdown
  2. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,744
    Scotland
    PP764's, turbo and mapping
  3. Talisman
    Talisman New Member
    Jun 6, 2012
    16
    Skoda Octavia sdi
    The steering wheel connects to the steering column. The steering column has a universal-joint at floor level - this is hidden behind a black plastic shroud below the pedals. The shroud is secured by two large plastic screws. When you remove the shroud, you will notice that there is a small pinch-bolt securing the lower part of the u/j to a spline - that spline is input shaft of the steering rack. Unscrew and remove the pinch bolT, and lift the steering wheel to it's maximum height adjustment, and the u/j will pop right off, the steering rack splined input shaft.
