SEAT Altea 1.9 TDI P0113 engine error
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by guinness, Jul 2, 2013.
  1. guinness
    guinness New Member
    Jul 2, 2013
    6
    Seat Altea 1.9TDI 2006
    Hi guys.
    Starting the engine in one of the summer mornings have got the check engine light on on my Seat Altea 1,9 TDI (as fare as I know it is same engine as Golf 5). Also the power of the engine wend down significantly. The car dos not react as usual when opening the throttle. Have check the engine with my scanning tool and got P0113 error - Intake Air Temperature Sensor 1 Circuit High. And the reading shows -38 degrees Celsius. Have tried to locate the IAT sensor but just can't find it. It is definitely not on my Bosch MAF sensor - only 4 wires and there is no wired sensor on side of it. Any ideas where can I find IAT sensor? Thanks a lot!
    23,900
    They are usually on the intake piping, it should be with the MAP sensor, either close to the intercooler or on the plastic pressure hoses.
  3. guinness
    guinness New Member
    Jul 2, 2013
    6
    Thanks a lot... is there any chance to get a picture with approximate position? Thanks a lot!
  4. Keithuk
    7,073
    VAG Error Code: 16497
    EOBD II Error Code: P0113
    Fault Location:
    Intake Air Temperature (IAT) Sensor (G42) - High Input
    Possible Cause:
    Malfunction Indicator Lamp (MIL)(K83) Triggered on first occurrence.
    Wiring open circuit/short to positive.
    Earth wire defective.
    Intake Air Temperature (IAT) Sensor (G42).
    Engine Control Module (ECM).
    Sorry about the large picture its the only one I could find, and thats a Leon.
    [​IMG]
  5. guinness
    guinness New Member
    Jul 2, 2013
    6
    Thanks a lot Keith. But this is MAF sensor... my IAT sensor is not integrated in MAF senzor. The IAT sensor should look something like picture bellow... just do not know where to find it.
    [​IMG]
  6. guinness
    guinness New Member
    Jul 2, 2013
    6
    My Bosch MAF sensor does not have the wire senzor... only 4 wires - the Bosch MAF sensor with IAT sensor has got the wire sensor on it... see the picture of mine.
    [​IMG]
  7. Keithuk
    7,073
    Ok try this.
  8. guinness
    guinness New Member
    Jul 2, 2013
    6
    I think it is a MAP sensor... will give it a try tomorrow. Thanks a lot.
  9. guinness
    guinness New Member
    Jul 2, 2013
    6
    Just one thing... where did you get the chart? Thanks
  10. Keithuk
    7,073
    22 is the MAP sensor there is no MAF sensor listed.
