Replacing the engine issues?
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by perrya, Apr 14, 2012.
  1. perrya
    perrya Member
    Dec 14, 2011
    153
    06 jetta
    what are the problems associated with replacing the engine with a TDI car? I ask because, I was reading that one guy did and then had all sorts of sensor signals that popped up after the new engine was installed, which was not a problem and drove fine.
    It sounded like another nightmare to replace the engine versus just the engine head, is this true? Is it just a matter of resetting the car's CPU because the old data is from the previous engine and a conflict exists?
    23,767
    No problems that I can think of. Nothing needs to be reset other than normal stuff from disconnecting battery.
  3. YMZ
    YMZ Super Moderator
    Sep 22, 2010
    2,089
    Jetta 2003, Golf 2001
    Replacing an engine requires a much less sophisticated level of mechanical ability... It's possible (likely!!!) that this person may have damaged some of the wires going to the various sensors (or the actual sensors) during the removal and replacement process...
    Yuri
  4. Bryant
    Bryant New Member
    Feb 21, 2012
    6
    audi a4
    and I want to know how does he should do?
