Rain sensing wipers on VW Passat need activation w/vag-com VCDS to use rain sensor
Discussion in '2012-2016 VW Passat TDI forum' started by chittychittybangbang, Sep 23, 2011.
  1. chittychittybangbang
    23,900
    Well, another mystery of VW parts is solved. The ad brochures for the 2012+ VW Passat say it has intermittent wipers, however, some people say it does not have rain sensing wipers. The rain sensor is clearly visible, it's the thing the rear view mirror is attached to. The sensor is also used for automatic headlights which is enabled from the factory. As it turns out, the rain sensing function of the sensor is probably disabled from the factory. If you don't want it, you're all set. If it's enabled and you want it, leave it alone. If it's not enabled and you want it, below is the procedure.
    Use your VCDS tool, go to CECM (central electric) module, enter long coding for the RLS (rain-light sensor), and unclick the checkbox for "Rain sensor inactive". Save and exit. It will now be active.
    Here is how to do it: http://www.myturbodiesel.com/1000q/b7/vw-passat-auto-wiper-activation.htm
    http://www.youtube.com/watch?v=x00TpDXY4sE
  2. MyAvocation
    MyAvocation Member
    Aug 6, 2011
    254
    Jetta TDI 2006.5
    Well done, Sir... will be on my short list of immediate mods.
  3. darrelld
    darrelld Member
    Nov 4, 2010
    167
    2012 Passat SEL TDI, 2013 Ford C-Max SEL Hybrid
    ScanGaugeII, BlackVue Dashcam, V1 Radar Detector H
    Thanks, I will look into this when my Passat arrives.
  4. chittychittybangbang
    23,900
    .......and it's done. I have updated the first post with the details on how to do this. I am still putting together a DIY list for the NA Passat, will update when done.
  5. skinnyb
    skinnyb Member
    Jun 24, 2011
    77
    2012 Passat SE TDI DSG
    35% tint so far
    I did mine yesterday and it definitely works. Thanks for the info. Now if we can get the windows via remote up and down I will be stoked.
  6. chittychittybangbang
    23,900
    I tried to do the comfort remote but couldnt' get it to work. The checkbox is there but it does nothing. Perhaps this might change in the future with different control modules or software updates but for now, it doesn't work. To make all windows go up-down, you can hold the driver's window button with the door open.
  7. MyAvocation
    MyAvocation Member
    Aug 6, 2011
    254
    Jetta TDI 2006.5
    I also heard talk of the rain sensor having the ability to auto-close windows/sunroof. Anyone test this yet?
  8. TDICT
    TDICT New Member
    Sep 28, 2011
    12
    2012 Passat TDI SEL
    Yes, chittychittybangbang did my car and it does work. I am sure he will chime in with the details
  9. skinnyb
    skinnyb Member
    Jun 24, 2011
    77
    35% tint so far
    I tried as well but mine doesn't work either. I sent my auto scan to Ross Tech with hopes that they might be able to figure it out soon.
  10. chittychittybangbang
    23,900
    Yes, I just finished the video and the writeup, http://www.myturbodiesel.com/forum/...-passat-tdi-sel-vcds-mod-vag-com-trick-10390/ see this post for any questions and support on that article.
    Nice meeting you TDICT, if you happen to leave the windows open for more than a day, please let me know if the windows close by themselves. I am interested to know if this is also the case on the Passat. It should but you never know!
  11. Kchorro
    Kchorro New Member
    Oct 20, 2011
    75
    2012 Passat TDI SEL Premium
    How can I get it done on my TDI SEL?
    Anybody that does this service in North Texas?
    I really appreciate our help.
  12. chittychittybangbang
    23,900
    Don't know anyone in Texas but asking here is a start.
    To do it, read the linked article. All the steps are in there, you don't want to see a 5 minute blurry video of a laptop screen anyways, the video is only the demo.
  13. darrelld
    darrelld Member
    Nov 4, 2010
    167
    Just activated Rain Sensing Wipers. Works great, now if there were only some rain to tweak sensitivity.
    Off topic, does anyone know the location of the DPF values on the 2012 Passat TDI?
  14. Keithuk
    7,073
    Now these Rain Sensing Wipers must have the rain sensor behind the interior mirror to work. If its there why aren't they enabled as standard?
  15. chittychittybangbang
    23,900
    Nobody knows. My only guess is that it's related to the pre delivery inspection and not changing the transport settings. There are a few changes that they have to make when the deliver the car. But I don't think this is it because VW's spec sheet doesn't say rain sensing wipers, only intermittent wipers.
  16. chapmanje
    chapmanje New Member
    Oct 23, 2011
    2005 vw tdi golf
  17. Kchorro
    Kchorro New Member
    Oct 20, 2011
    75
    Darrell,
    Where you did activate them?
    Let me know. I want to do it to my.
  18. Joyrex
    Joyrex New Member
    Nov 3, 2011
    2012 Passat TDI SEL
    $599 for the cable? Possible and safe to get cheaper somewhere like ebay?
  19. darrelld
    darrelld Member
    Nov 4, 2010
    167
    You will need the VCDS software to activate. I can do it but would not assume any liability from changing your cars setting from factory.
  20. Kchorro
    Kchorro New Member
    Oct 20, 2011
    75
    I just got done in my car from a local vag-com user.
    thanks for the offer.
    I'm wondering if there is any update to fix the opening and closures of windows from the key fob? Ross-tech has been working on it or any other source.. Ay updated on this issue?
