Radio from a 2013 from the TDI buy back
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by Rj marks, Dec 21, 2016.
  1. Rj marks
    Rj marks New Member
    Mar 14, 2014
    6
    2006 vw jetta TDI
    Norway, Maine
    I have a 2013 jetta sports wagon TDI thats part of the buy back and an 06 TDI that I will never get ride of .
    Is it worth taking the VIII radio out of the 13 and putting it in the 06?
    I like the blue tooth and other opt. it has ,But is it worth it and if so how much of a job Thank you
    23,902
    I would, it's plug-play. You just need to get the radio unlock code. I'd at least put the old radio in the new car since that has almost no value anyways.
    The bluetooth will require more work. You'll need to swap the module, if not part of the nav, overhead console, and then make your own wiring harness. You should be able to find a wiring harness kit online.
  3. Rj marks
    Rj marks New Member
    Mar 14, 2014
    6
    2006 vw jetta TDI
    Norway, Maine
    Thanks. Is there a list to make sure I get it all? Or any odd parts to look for?
    A gen Thanks this site has been a grate help
  4. chittychittybangbang
    23,902
    1 Radio unlock code.
    2. bluetooth module, may be under pass seat
    3. overhead console.
    4. You could try cutting pigtails off the wiring but unless you have a wiring diagram and want to be nice, just get a retrofit harness.
    5. Radio unlock code.
    6. VCDS to code it all and let your car know it's there.
    6. Radio unlock code.
  5. Rj marks
    Rj marks New Member
    Mar 14, 2014
    6
    2006 vw jetta TDI
    Norway, Maine
  6. leocat66
    leocat66 Member
    Nov 5, 2016
    59
    V W, 2006 JETTA, TDI
    Slidell, Louisiana
    No intent to hijack your thread. I have no idea if what you wish to try with the radio will work, however I was interested in why you feel that strongly about your '06. We have one also and have had three other TDI cars. A 2014 Beetle, which is going back, a 2013 Passat ready for the fix, and a 99 Jetta which finally died. The '06 has been our favorite.
