problems need urgent help
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by daypass72, Nov 27, 2010.
  1. daypass72
    daypass72 New Member
    Nov 27, 2010
    10
    2006 Jetta TDi
    This am I changed the engine oil and filter in my 2006 Jetta TDi, started it up to check the oil level and topped it up to specific level. My wife drove the car few blocks away to get some lunch. She called me and said the car will not start. I went over and the battery was dead. I boosted it and drove it home. I charged it up and load tested it and and its dead. I bought a new battery and installed it and it fired right up.
    1hr later I was out with the car, came out of the store and it will crank but will not start.
    There was a slight smell of burning rubber coming from inside the car near the fuse panel. I checked all the fuses and they are all ok. even the ones under the hood on the drivers side. There is a possibility i may have put a fuse in the wrong spot while checking them but slight chance.
    I am lost here and need the vehicle asap, its the only one we have :(
    any idea's what could be the problem??
    Thanks
  2. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,792
    Scotland
    PP764's, turbo and mapping
    Check the 109 relay bud. It's usually located in the same fuse box on most cars. It might be what's making the smell.:) Also have you checked the 1000 faq and index for your car? I would think there'd be some helpful info in there.
  3. daypass72
    Nov 27, 2010
    10
    2006 Jetta TDi
    Thanks seat man, there are more relay an such under the sterring column, I have not cecked the 1000 faq yet i will see if i can locate that.. Is there a procedure to check the relay (109) after I find it?
  4. Seatman
    Jul 9, 2010
    5,792
    Scotland
    Most people just try a new one but you could prise the cover off carefully and you'll see a coil thing with a thin, flat piece of metal at one end. In between this and the coil thing is a set of contacts, try giving them a clean with some fine sand paper, ideally wet and dry. You could also check this trouble shooter.
    http://www.tdiclub.com/TDIFAQ/TDiFAQ-8.html
  5. daypass72
    Nov 27, 2010
    10
    2006 Jetta TDi
    from what I have read so far, 109 relay's are found an older model TDI?
  6. Seatman
    Jul 9, 2010
    5,792
    Scotland
  7. chittychittybangbang
    23,889
    Correct, your car doesn't have a relay 109. None did after 2003. It was a common failure point which was fixed but it's possible your car is still having a relay problem.
    And FYI, the FAQ linked to on the other site was last updated in 2003...his car is 2 major changes newer than when it was last updated (2004,2005.5) so some of the information there can be misleading such as checking the fuel filter T or injection pump, or the fact that each GP on his car has a separate wire instead of all running off the same wire.
    Burning rubber smell could be an electrical problem. Does your car have any mods?
    Some possibilities are the lift pump in the fuel tank not working (electric fuel pump) - can you hear the pump prime when you go to start the car?
    Does the glow plug light on the dash board light up as intended?
    If you had a code reader it would help to figure out what the problem is.
    Did you leave a tool in the engine bay which damaged the wire harness? Maybe something got moved and shorted out? Check for cracks in the wire harness.
    Check the wire harness going into the head on the driver's side. It runs the injectors.
    It shouldn't cause it, but does your door wire harness have any cracks? http://www.myturbodiesel.com/1000q/a5/wiring-harness-vw-jetta-repair.htm Maybe the alarm is preventing the car from starting. I don't know if it will prevent starting but allow cranking because the anti theft system is built into the central electric module.
    This may sound strange, but if you leave the car on and let it sit there for a while, does it make any difference? Changing the battery or adding oil shouldn't cause any problems. And because it won't start at all, it's not the immobilizer system.
  8. shftdrvr
    shftdrvr New Member
    Aug 9, 2008
    96
    Is the new battery the correct rating? If the battery cranks the engine too slowly it won't start.
  9. Seatman
    Jul 9, 2010
    5,792
    Scotland
    Slightlyofftopic2Is there a problem starting faq on here Chitty? I haven't found one yet to direct people to. I like to try and help where possible and the more faq things I can find the better because I don't know the modern cars like others do.:)
  10. daypass72
    Nov 27, 2010
    10
    2006 Jetta TDi
    no mods all stock, no tools left in the engine bay, glow plug indicator is not showing up at all,
    from what I have read mine is a 2006 but build date was oct 2005 making mine a 2005.5
    I assume a relay for the glow plugs is stuck closed causing the draw. I disconnect every fuse and disconnected the alternator and still a draw..
    I am about to give up on this, its driving me mental lol, looks like I am renting a car until i fix it or take it the dealership and get hosed.
    Any other suggestions??
    Cheers
  11. daypass72
    Nov 27, 2010
    10
    2006 Jetta TDi
    forgot to mention my scanner will not connect to the car, have used same one numerous times on my car without issues connecting to it
  12. chittychittybangbang
    23,889
    hm...the GP relay is J370 if that's any help.
    When you replaced the battery, did you remove the shelf and remove any of the relay cables? The shelf has a corner which gets stuck on the fusebox under the hood so you have to remove one of the cable to get it out.
  13. daypass72
    Nov 27, 2010
    10
    2006 Jetta TDi
    removed the battery without any issues, i just have to locate the glow plug relay and start from there I guess. The wiring and relays are totally different from 2005.5 to 2006 model this is what is confusing me
    I am positive I have narrowed it down to glow plug relay faulty (welded closed) causing a draw. I am hoping i can find the faulty relay, replace it and everything will be fine.
  14. daypass72
    Nov 27, 2010
    10
    2006 Jetta TDi
  15. daypass72
    Nov 27, 2010
    10
    2006 Jetta TDi
    UPDATE
    pulled every relay out one at a time, all fuses again one at a time, disconnected just about every wiring connection, still a fairly large draw on the battery. I am totally lost here. Anyone have some gas and a match?? no glow plug light on the dash display all relays are fine. scanner will not connect with the up to the ecu, tried 3 different scanners same problem.. any help would be appreciated
  16. Seatman
    Jul 9, 2010
    5,792
    Scotland
    Sorry about the miss information earlier bud. Have you checked the ecu connections and also is it nice and dry? I don't know where yours is located but on my car it's below the windscreen and mine was soaked which caused me some problems when I first got the car.
  17. daypass72
    Nov 27, 2010
    10
    2006 Jetta TDi
    no worries seatman.. I have not looked at ecu connections yet, I think its located in the same place as yours..
    this is driving me insane lol
