Please help, oil sump removal problem
Discussion in 'General Diesel Discussion' started by penthro, Aug 3, 2012.
  1. penthro
    penthro New Member
    Aug 3, 2012
    seat toledo 1.9tdi
    Hi Folks, hope some one can help.
    I have a seat Toledo with a vw 1.9tdi engine, this is a x reg so late 90s i think.
    I have cracked the sump pan and it is buggered, decided the best thing as i have a garage some tools and a pit is just to replace it myself, i live on a small island and no garage for a convenient distance.
    I ahve removed all the small 10mm bolts, one larger bolt and three large ones that slide in horizontally, the trouble is the sump pan just wont come loose.
    I am used to wokring on much older cars, where normally the sump pan comes off easially,
    I cant figure out what i have missed, but really need to get this fixed.
    If any one can offer any advice of any kind i would be extreamly greatfull, as currently very stuck indeed.
    Cheers,
    Clint.
    23,767
    If you're sure no bolts are on, gently knock it with a piece of wood and a hammer. It uses gasket maker so it'll be glued on a little bit.
  3. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,744
    Scotland
    PP764's, turbo and mapping
    Did you get these hidden ones out?
    [​IMG]
    I used this, a 5mm ball ended allen key, did the trick
    [​IMG]
    If you have them out then yeh, hit it till it drops, it's not like it isn't busted already lol
