pd 150 accesive white smoke problem
Discussion in 'Diesel Cars and SUV' started by b55can, May 14, 2016.
  1. b55can
    b55can New Member
    May 14, 2016
    Seat leon
    ankara
    Hi ,
    i have pd 150 seat toledo 2003 , i have very difficult times since 1 year ,
    One morning suddenly shows white oil smoke , i have no problem before about 1 year (12000 km)
    white smoke mostly seen on idle , under acceleration gone, wait on idle 1 min touch acceleration pedal about to 2500 rpm gives again after 2500 rpm gone
    [​IMG]
    What we done so far and nothing change
    1-Turbo removed , oil ring changed , o-ring changed , balanced put back on car, nothing change
    2- injector seal changed
    3- head removed, valve seals changed , new head gasget applied
    Nothing Changed
    Bye the way there is no power issue , car goes very well
  2. b55can
    b55can New Member
    May 14, 2016
    Seat leon
    ankara
    After all this
    4- Head changed with low millage second hand head (never sanded), gasget ,seals , ─░na Valve Lifters changed again
    5-Block opened seen %4 wearing/ovality whatever on 4th bore other bores % 1-2 wearing/ovality
    6-Mahle pistons removed , bores honed , piston rings changed 79,5 mm new kolbenschmidt ring set/spacer , rod bearings changed with new kolbenschmidt ones.
    i spent too much money and time still nothing changed , i am out of idea please give some ideas
    i am about change 4 pistons with brand new mahle pistons and buy standard cylinder liner set
    New Second hand head photo after opened second time
    [​IMG]
    [​IMG]
    And oil cleaning on the 4th bore
    [​IMG]
