Passat OEM Parking Sensor Retrofit/Upgrade
Discussion in '2012-2016 VW Passat TDI forum' started by clarkent5477, Feb 12, 2012.
  1. clarkent5477
    clarkent5477 Member
    Jan 10, 2012
    55
    2001 VW GTI, 2012 VW TDI SE SunNav
    23,889
    Since it's only the beeping or light one, any aftermarket solution would be identical in function. I don't know if there's a green-yellow-red light but if not you can go off the tone, both work the same. For $450+install I'd go aftermarket.
  3. Texpar
    Texpar New Member
    Oct 16, 2011
    15
    2012 Passat Opera Red TDI SEL
    any good after market systems that tie into the RNS unit?
  4. chittychittybangbang
    23,889
    No, if you want the OEM functionality you have to get the OEM part. It'll just be a display on the RNS. The backup camera is a whole 'nother deal.
  5. ranjr13
    ranjr13 Member
    Dec 7, 2011
    70
    2012 TDI SEL Platinum Gray/Moonrock
    Dealer says will integrate nicely, so there's one on order to be installed when the car ever gets here...along with the block heater that the dealer's not too happy about...
  6. clarkent5477
    clarkent5477 Member
    Jan 10, 2012
    55
    Sweet! Let us know how it goes.
