Passat Immobilizer
Discussion in 'VW Mk3 Jetta, Passat TDI and other/older diesels' started by Keithuk, Dec 2, 2010.
  1. Keithuk
    6,813
    Hi guys/gals.
    We have a 1996-97 Mk3 Passat 18T at College I'm afraid its petrol but I would say the diesel versions would have the same problem. We've had it a couple of months and the battery is slowly going. Today the students were told to replace the battery with a new one which they did. Now the immobilizer light is flashing and it only runs for a couple of seconds which points to the immobilizer.
    I've read everything in FQA now I'm presuming because of the year it has a immo 1 which wasn't released in the States before 1999 with a immobilizer. I've read that you can leave the key in the ignition for 10 minutes and it should correct the fault. Some say leave the ignition on for 10 minutes to correct the same problem. I've tried both options and the immobilizer is still flashing.
    Any sugestions? ;)
  2. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,744
    Scotland
    PP764's, turbo and mapping
  3. Keithuk
    6,813
    Thanks for the links but I don't thing they are relavant. A lot say that immobilizers weren't fitted before 2000 well this is a UK model and it was. A lot talk about lost keys the need recoding we haven't lost it. I noticed today that the led on the remote doesn't light when you press either button. Autodata says it needs the dealer to recode if you change the battery in the remote.
    Volkswagen Passat (96-00) 1,8 1996-00 Engine code: ADR
    Remote alarm/central locking
    System operation
    Alarm functions can be altered using diagnostic equipment.
    08/97→: Interior movement sensors deactivation switch located in 'B' pillar.
    Some models: Key may be fitted with boot/tailgate release button.
    Pressing key lock button twice within 5 seconds deactivates alarm and double locking system.
    Pressing key unlock button once deactivates system and unlocks driver's door only.
    Pressing key unlock button twice within 5 seconds deactivates system and unlocks all doors and boot.
    If vehicle unlocked and doors or tailgate not opened within 30 seconds, locks are reactivated.
    Interior lamp switched off when arming system.
    Interior lamp illuminates for approximately 30 seconds when disarming system.
    Synchronization
    When
    Key buttons operated repeatedly while vehicle out of range and system becomes inoperative.
    How
    Press key lock or unlock button for approximately 1 second.
    Manually lock or unlock vehicle.
    System should now lock or unlock vehicle.
    If not, carry out programming procedure.
    Programming
    When
    Key added or replaced.
    System malfunction.
    How - →98MY
    Keys can only be programmed using diagnostic equipment.
    NOTE: A maximum of 4 keys can be programmed.
    How - 99MY→
    Switch ignition ON.
    Insert key to be programmed into driver's door lock.
    Lock vehicle manually.
    Press lock or unlock button.
    Wait at least 1 second.
    Press lock or unlock button again.
    Vehicle horn sounds to indicate correct programming.
    Keys can also be programmed using diagnostic equipment.
    Its a type 1 key, 2 buttons.
    Immobilizer
    System operation
    System arms after switching ignition OFF.
    Switch ignition ON.
    Ensure immobilizer warning lamp illuminates for approximately 3 seconds.
    Programming
    When
    System malfunction: Switch ignition ON. Immobilizer warning lamp flashes or illuminates continuously.
    System malfunction: Engine runs for approximately 1 second, then cuts out.
    How
    Immobilizer can only be programmed using diagnostic equipment.
    I've emailed http://www.gendan.co.uk/ and http://www.ilexa.co.uk/ the English distributors to ask about cost and discount for the VCDS (VAG-COM) HEX-USB+CAN Interface Package. ;)
  4. Seatman
    Jul 9, 2010
    5,744
    Scotland
    I do find the internet useful and useless sometimes as it's not always easy to know who knows what. There seems to be tons of rubbish info and you have to dig through it to find what you're after. Anyway I'll look out for a post when you get the car sorted.
  5. Keithuk
    6,813
    I had a reply of Gendan today and they do a VCDS (VAG-COM) HEX-USB+CAN Power Bundle which includes LT Van adaptor, 2x2 Adaptor, USB Extension Cable and a carry case for £299.95. I'm trying to negotiate educational discount on this. I also had a reply of Ilexa and theirs was virtually the same but they charge £5 P&P.
    They do the normal VCDS (VAG-COM) HEX-USB+CAN Interface Package for £262.95 with free delivery which I think I will buy shortly. Ross-Tech price is $349 - £222 which is a bit cheaper that Gendan but its UK and any problems its easier to contact them than sending it back to the States. ;)
  6. Seatman
    Jul 9, 2010
    5,744
    Scotland
    Could you not say it's a vital piece of equipment and get the college to pay for it? Lol, I bet you couldn't.
  7. Keithuk
    6,813
    I've stated its a useful peice of kit for any Audi, Seat, Skoda and VW cars but my programme manager is tight as a ducks backside, he's worried about paying £600 for a plasma cutter for the bodywork section.
    I had an email back of Ilexa and they said they can give us a 20% educational discount off the price. Because PM doesn't want to spend any money I've opted for the basic VAG-COM/ VCDS Interface Package for £219.30 + VAT + £5.50 P&P and I presume the 20% discount. I also had an email back of Grendan after I asked if they could match the discount we were offered from Ilexa. They said
    I checked the key the other day which the led doesn't light when you press the buttons which its probably the battery gone duff. I was talking to another technician about this problem he has a 2005 Seat Leon 2 he said bring it over and we will change the battery. Its the same CR2032 battery they use in the welding masks. We changed the battery and the led still didn't light up. He says you get the key working turn on the ignition and lock and unlock the doors that switches the immobilizer off, well it does on his Seat. With the buttons operating we can't try that. I bought a 6 pack of batteries this afternoon, 2 CR2032, 2 CR2025 and 2 CR2016 for 99p. I'm not sure that will do anything but at least we are starting with a new battery.
    The http://www.ilexa.co.uk/ site has different sections that you have to use a username and password to access but I don't see anywhere to register. I asked them about this today we will have to see what they say. ;)
  8. Keithuk
    6,813
    I fitted the new battery to the key today now the led lights and the central locking works again though one of the rear doors didn't lock or unlock. My friend at work said turn the ignition on and press the lock and unlock buttons and that should remove the immobilizer it didn't.
    I emailed Ilexa yesterday to ask if they are authorized dealers for Ross-Tech after what Gedan said Derek's reply was
    So it was some sales crap from competitors.
    Ilexa have a ilexa Onboard Diagnostics Forum. When I tried to register this morning it asks for a number of Ilexa. I had a message to phone Derek this morning so I phoned him back this afternoon. He explained his dealings with Ross-Tech virtually as per email. I asked him about the number to register for the forum. He said customers are informed about the forum and are given the reference number so we will have to wait until we buy the VCDS.
    It also says they aren't taking new members at the moment. He said customers are allowed in. ;)
  9. Keithuk
    6,813
    I was told today after a week we aren't buying VCDS for £170 + VAT (as we get the VAT back) they are going to ask students if they have one they can bring in, tight barstuards. Alright the car was given to use but thats not the piont its having the current equipment to do the job.
    I'm still going to buy one for myself (a Christmas present for myself) and no they aren't borrowing it. Our programme manager used to be a motor vehicle lecturer 20 years ago but he's been doing a pen pushing job for the last 15 years nothing to do with motor vehicle, he only got this position because his job was up for redundancy. He's that way out of touch with things and he's in charge of the motor vehicle section. But thats typical of bosses they only hear want they want to hear. ;)
  10. Keithuk
    6,813
    They are going to ask if any students have VCDS to fix it if they don't they are gloing to pay £50-£80 for VW to come out and fix it.
    Ok I've ordered my own VCDS from
    http://www.ilexa.co.uk/acatalog/vagcom.html
    So I can now charge them £50 to get it fixed. ;)
  11. Keithuk
    6,813
    Ok my VCDS arrived today. I've installed the software and plugged the lead in. Obviously I don't have the car in the home and I'm not going out to the freezing garage so it will have to wait for the weekend.
    You can download the manual if you want too http://www.ross-tech.com/vcds/download/current.html
    I might take it to work tomorrow and try it on the Passat. I will let you know if I succeed. ;)
  12. Keithuk
    6,813
    Not much luck at the moment. It shows an error on 11 - Immobilizer: No responce from Controller. Derek says it could have the Immobilizer controller on the steering column or it could be in the instrument pack. I've had the column off and there is nothing connected so its probably in the instrument.
    A full autoscan brings up
    Address 02: Auto Trans
    Protocol: KW1281
    Part No: 01N 927 733 CJ
    Component: AG4 Getriebe 01N 3436
    Coding: 00000
    Shop #: WSC 00000
    Address 03: ABS Brakes
    Protocol: KW1281
    Part No: 8E0 614 111
    Component: ABS 5.3 FRONT D11
    Coding: 0273004132
    Shop #: BB 24303
    Address 15: Airbags
    Protocol: KW1281
    Part No: 3B0 959 655 B
    Component: Airbag VW 3 V00
    Coding: 00066
    Shop #: WSC 05311
    Address 46: Central Conv.
    Protocol: KW1281
    Part No: 3B0 959 796 P
    Component: Zentral-SG Komfort V41
    Coding: 04097
    Shop #: WSC 05311
    Address 02: Auto Trans Labels: None
    Coding: 00000
    Shop #: WSC 00000
    VCID: 7BF07A504363
    1 Fault Found:
    00532 - Supply Voltage B+
    35-10 - - - Intermittent
    Address 03: ABS Brakes Labels: 8E0-614-111-ABS.lbl
    Shop #: BB 24303
    VCID: DBB09AD063A3
    No fault code found.
    Address 15: Airbags Labels: None
    Coding: 00066
    Shop #: WSC 05311
    VCID: 2E568304C091
    1 Fault Found:
    07-10 - Signal too Low - Intermittent
    Address 46: Central Conv. Labels: 3B0-959-79x-46.lbl
    Coding: 04097
    Shop #: WSC 05311
    VCID: 428EC7B46409
    23 Faults Found:
    01329 - Convenience System Data Bus in Emergency Mode
    01334 - Door Control Module; Rear Right (J389)
    49-00 - No Communications
    01333 - Door Control Module; Rear Left (J388)
    49-10 - No Communications - Intermittent
    01332 - Door Control Module; Passenger Side (J387)
    01331 - Door Control Module; Driver Side (J386)
    00951 - Tailgate Central Locking Motor Relay (J398)
    28-10 - Short to Plus - Intermittent
    01135 - Interior Monitoring Sensors
    36-10 - Open Circuit - Intermittent
    37-10 - Faulty - Intermittent
    01179 - Incorrect Key Programming
    35-00 - -
    01330 - Central Control Module for Central Convenience (J393)
    37-00 - Faulty
    00668 - Supply Voltage Terminal 30
    00932 - Electric Window Motor; Drivers Side (V147)
    00928 - Locking Module for Central Locking; Front Driver Side (F220)
    27-00 - Implausible Signal
    00943 - Heated Exterior Mirror; Driver Side (Z4)
    35-00 - -
    00933 - Electric Window Motor; Passenger Side (V148)
    00944 - Heated Exterior Mirror; Passenger Side (Z5)
    35-00 - -
    00934 - Electric Window Motor; Rear Left (V26)
    00930 - Locking Module for Central Locking; Rear Left (F222)
    27-10 - Implausible Signal - Intermittent
    I cleared all codes and scanned again and it shows
    Coding: 00000
    Shop #: WSC 00000
    VCID: 7BF07A504363
    1 Fault Found:
    00811 - System Not Ready for Interrogation (Ross-Tech; Check Fault Codes Later)
    35-00 - -
    Shop #: BB 24303
    VCID: DBB09AD063A3
    Coding: 00066
    Shop #: WSC 05311
    VCID: 2E568304C091
    Coding: 04097
    Shop #: WSC 05311
    VCID: 428EC7B46409
    1 Fault Found:
  13. Seatman
    Jul 9, 2010
    5,744
    Scotland
    Found it at last, What's the latest on this one Keith?
  14. Keithuk
    6,813
    Thanks for asking.
    I've got no further with it because it won't comunicate with the immobilizer or instruments it shows No responce from Controller on both. The thing is there is no control/instruction given to the students they are just told dismantle the brakes and are left to it, so things get broken or lost. The problem is when you have 15 lads in a workshop usually working in pairs thats 7 different jobs being undertaken so they can't watch everything. I've suggested they do it as a class exercise to you can what they are all doing but they won't do that. So there could be a problem that someone has unplugged or cut wires or what ever as they love to destroy everything.
    The College still won't buy one so stuff them. ;)
  15. Seatman
    Jul 9, 2010
    5,744
    Scotland
    Lol oh well, rather you than me having to deal with that lot.:D
  16. Keithuk
    6,813
    We had a demo of the Bosch KTS 670 along with the Bosch Air Conditioner yesterday of Bosch. I thought while they were here lets see if they can get our Passat immobilizer reset?
    They did a full scan and picked up loads of faults but none refered to the immobilizer. I said VCDS can't communicate with the immobilizer no responce from controller, the Bosch one wouldn't either. The KTS machine has built in wiring diagrams for all makes and models. We brought up the Passat diagrams and traced the wires. The immobilizer feed pin 7 of the DLC via fuse 32 (20 amp). There was a supply to that fuse so its lost the connection to the immobilizer in the instrument for some unknown reason.
    Now we are thinking of buying the Bosch KTS 570 for the College. The 570 is exactly the same as the 670 but it runs of a computer/laptop via blue tooth dongle. Now the price of the 570 is £4,500 but because we are a College we get a better deal. Normally a garage would have to pay £600 each year for the Bosch updates and it has Autodata built in which cost £660 each year to renew the licence. We would get free updates of both softwares for life and the machine would cost us only £2,500.
    Thats sounds like a great deal so I think we will be having one or even two of them at that price?
