O2 Sensor Location
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by jreckeweg, Feb 26, 2012.
  1. jreckeweg
    jreckeweg New Member
    Sep 12, 2010
    5
    2010 Jetta TDI. 2006 Jetta 2.5
    Hey guys, so I am working on fixing this O2 sensor code that I have been having. Can someone tell me the location of 02 sensor Bank 1 Sensor 2?
    Just to make sure Im getting the right one if I replace it.
    Thanks
    Jeff
    23,900
    On the 2010 or 2006?
    2010 there's a bunch of sensors on dpf and by exhaust valve. FYI, have you tried clearing the code and seeing if it comes back?
    [​IMG]
    On the dpf the 02 sensor is the one on the top right sticking out at an angle. There's either one immediately after the DPF paired with a temp sensor or one at the exhaust valve. One of those is probably sensor 2. This is just a guess so if you find out please share!
    [​IMG]
  3. jreckeweg
    Sep 12, 2010
    5
    It's on the 2010. That would make sense as to which one or is. I am trying to get the dealer to do it for me under warranty, but it came on at 36300 miles. So we will see.
    I'll let you know which one it ends up being.
    Jeff
  4. Stan_cz
    Stan_cz New Member
    Apr 25, 2014
    2009 Jetta Sportwagen TDI, DSG
    Somerset, NJ
    Hi Jeff, I just got P2271 fault code on my 2009 Jetta SW TDI. It is supposed to be O2 sensor signal biased/stuck rich in bank 1, sensor 2. I guess it is the same as yours. Could you please confirm that it is the one shown on the scheme above between NOx and H2S converters? Is it easily accessible from underneath? Thanks, Stan
  5. Keithuk
    7,094
    EOBD II Error Code: P2271
    Fault Location:
    Oxygen (Lambda) Sensor 2, Bank 1/Heated Oxygen Sensor 2 (G130), Bank 1 - Signal Stuck Rich
    Possible Cause:
    Wiring/Connector(s).
    Oxygen (Lambda) sensor.
    Heated Oxygen Sensor 2 (G130).
    Fuel pressure.
    Injectors.
    Air intake restricted.
    Possible Solutions:
    Replace Oxygen (Lambda) Sensor 2, Bank 1/Heated Oxygen Sensor 2 (G130), Bank 1.
  6. Stan_cz
    Stan_cz New Member
    Apr 25, 2014
    Somerset, NJ
    Thank you, Keith.
