new member, service indicator/imobilizer problems
Discussion in 'New TDI forum member introductions' started by adamd, Mar 7, 2011.
  1. adamd
    adamd New Member
    Mar 7, 2011
    vw jetta 2003
    Hi new here, wondering if anyone has seen something like this before.
    2003 jetta
    turned the car on today and it dies after a second.
    on the cluster the key light was on.
    in the odometer at first it says service then changes to say mileage is 651533 miles (only really at 91k)
    vag-com says i have two faults 16804 and 17978.
  2. Keithuk
    6,943
    VAG Error Code: 16804
    Fault Location:
    Catalytic converter system, bank 1 - efficiency below threshold
    Possible Cause:
    Catalytic converter.
    VAG Error Code: 17978
    EOBD II Error Code: P1570
    Fault Location:
    Engine control module (ECM) - immobilizer active
    Possible Cause:
    Incorrect/damaged key.
    Incorrectly coded.
    Engine control module (ECM)/Immobilizer replacement without coding.
    Wiring.
    Immobilizer defective.
    As taken from my http://www.myturbodiesel.com/forum/f9/free-eobd-ii-error-codes-software-2919/ ;)
