MK7 - Golf Sportwagen TDI - DSG service
Discussion in 'Mk7 VW Golf, Sportwagen and Audi A3 TDI forums' started by Frotis, Jan 9, 2018.
  1. Frotis
    Frotis New Member
    May 29, 2017
    2015 Golf Sportwagen TDI, 2.0L and 2006 Jetta TDI, 1.9L
    Saxonburg, PA
    I picked up a 2015 Golf Sportwagen TDI (CRUA) with the DSG transmission recently. It's getting close to the 40K service interval. My previous TDI was a 2006 Jetta (BRM) with the DSG transmission. I've done the DSG service on my old Jetta several times. I was wondering if there was a newer oil spec for DSG transmission in my Sportwagen. Is the VW TL 052 182 oil spec still the same for my 2015 Golf Sportwagen DSG transmission? I was using Ardeca Matic-Pro DSG oil in my old Jetta. Any thoughts? Comments? Suggestions?
    Jared
    Saxonburg, PA
  2. Keithuk
    7,235
    ETKA doesn't list Golf Sportwagen even if you select USA, that engine code CRUA. The Sportwagen is generally USA only.
    Manufacturer: VW, Date(s) Used: 01/2014-06/2015, Model: Golf, Engine Code: CRUA, 110Kw, 150PS, 2.0 Ltr, 4 Cyls, Remarks: North American Region (NAR): Turbocharged Direct Injection Common Rail (TDI-CR)
    Manufacturer: Audi, Date(s) Used: 05/2014-05/2015, Model: Audi A3/S3/Sportback/Limousine/Quattro, Engine Code: CRUA, 110Kw, 150PS, 2.0 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Common Rail (TDI-CR)
    Can you do me a favour and post the gearbox/transmission code so I can add both to my app?
    ETKA shows for 2015 Golf with 6 speed DSG. Transmission oil - G052 527 A2 - £35.47 for 1 litre.
    http://www.ardecausa.com/products/automatic-transmission-fluid/matic-pro-dsg.php
  3. Frotis
    Frotis New Member
    May 29, 2017
    Saxonburg, PA
    I will look up the code and post it when I find it. Can you double check the oil number you posted? The G052 527 A2 number that you listed is very close to an oil code I find on a various vendors DSG products. For Example Febi/Bilstein offers a DSG oil that has G052 529 A2 on the label.
  4. Frotis
    Frotis New Member
    May 29, 2017
    Saxonburg, PA
    I looked in Maintenance booklet on the sticker with the VIN, Eng Code, Trans. Code, Option Codes, etc... The transmission code is QSD and it lists the vehicle as a Variant 2.0 TL.
  5. Keithuk
    7,235
    As I've said ETKA don't list the Golf Sportwagen that's what's part number is listed for 2015 Golf with a 6 speed DSG.
