misfire number 1 cylinder
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by brisnw, Apr 22, 2012.
  1. brisnw
    brisnw New Member
    Feb 21, 2012
    17
    200 tdi
    is number 1 cylinder the one by timing cover or back of motor by thermostat I have number 1 missfire code
  2. Fingers
    Fingers Member
    Aug 17, 2011
    49
    2004 Jetta TDI
    Manitoba
    It's by the timing belt cover.
  3. Keithuk
    6,818
    I'm sure I've read YMZ saying they doesn't number the cylinders in the conventional method cylinder 1 being next to the timing cover, this my depend on the model year.
    Do you have an error code for this missfire?
  4. brisnw
    brisnw New Member
    Feb 21, 2012
    17
    200 tdi
    I have a error code for number 1 missfire and glow plug (a) circut failure that is the injector that I pulled to check pump pressure so will take it out to have it checked then deal with glow plug circut issue
  5. Keithuk
    6,818
    Yes but what is the error number?
    Car: 200 tdi
    What is that a 2000 model but which model please add the model and correct year to your car spec?
  6. brisnw
    brisnw New Member
    Feb 21, 2012
    17
    200 tdi
    p0301 and p0380 2000 jetta 1.9
  7. Keithuk
    6,818
    You still hsven't updated your car spec.
    VAG Error Code: 16685
    EOBD II Error Code: P0301
    Fault Location:
    Cylinder 1 - Misfire detected
    Possible Cause:
    Wiring.
    Ignition system.
    Fuel injectors.
    Fuel pressure.
    Running out of fuel.
    EVAP canister purge valve.
    Evaporative emission system.
    Low compression.
    Base engine problems.
    Engine control module (ECM).
    Special Notes:
    This feature search for engine misfire in a specific cylinder. Most of the time the cause for a misfire is a lack of combustion in a cylinder due to absence of spark, poor fuel metering, or poor compression.
    VAG Error Code: 16764
    EOBD II Error Code: P0380
    Fault Location:
    Glow Plug/Heater (Q6) - Circuit malfunction
    Possible Cause:
    No Pre-Glow Period.
    Poor Cold Starting.
    Wiring.
    Glow plug relay (J52).
    Fuse.
    Glow plugs.
    Possible Solutions:
    Check Glow Plug Wiring.
    Check Glow Plug(s).
    Special Notes:
    See TDIClub Glow Plug 101
