Manual transmission switches and sensors
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by Gbcooper, Feb 20, 2011.
  1. Gbcooper
    Gbcooper New Member
    Feb 20, 2011
    2003 jetta tdi
    Intro post: 03 jetta tdi.
    I noticed that I don't have reverse lights so I am suspecting that I need to change out the sensor on the manual transmission. While inspecting the location I noticed another switch / sensor on the transmission from the bottom right above the starter. It has two wires one pulled out.
    What is it?
    is there a harness clip somewhere up wire?
    Where is the best place on line to find the revesse switch?
    Thank you
    Gordon
    23,900
    Pics of the broken wiring there are a lot of wires there? It could have rubbed through. Only thing I can think of is the starter wiring.
    Also post moved to mk4 section.
  3. grizzly
    grizzly New Member
    Jul 21, 2007
    298
    Well if you found some wires pulled out, are they for the reverse light sensor? The reverse light sensor is the one that is on the shifter linkage.
