Just picked car up from dealer now immobilizer problem no start
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by williamgd2, May 30, 2012.
  1. williamgd2
    williamgd2 Member
    Sep 3, 2011
    289
    Jetta 2010 TDI
    Ct. USA I need my Glow plugs
    oem backup camera,. oem type wing.,.9w7 bt, rns 510, 135lb real air horns seperate from regular horn and for emergency use only
    Just had 2 keys made and programmed at the dealer $500.00 later I get home and car won't start on the dash it says NO KEY dealer is closed. Is there anything I can do to get my car going? Can I shut off the immobilizer in vcds? Is there a way to relearn the key without having it towed back to the dealer? I don't know what the dealer did wrong maybe they didn't save the program.
    23,767
    can't shut off immo with VCDS, they don't have this function. Only way to shut off immo is a chip reflash to overwrite the programming.
    Try the immo faq troubleshooting steps, other than that you're SOL to get the car moving tonight. http://www.myturbodiesel.com/1000q/multi/immobilizer-VW-Audi-FAQ.htm You should be able to get into some of the measuring blocks and see the status of the key.
  3. williamgd2
    williamgd2 Member
    Sep 3, 2011
    289
    Jetta 2010 TDI
    It just keeps getting better. The dealer wants to charge me again to reprogram they are saying it is imposible that the car lost it program. The car has to be towed in again.
  4. williamgd2
    williamgd2 Member
    Sep 3, 2011
    289
    Jetta 2010 TDI
    Dealer just called my car was towed in and the key programming won't save for them either.What a mess because of a crappy Valet.
  5. Cogen Man
    Cogen Man Active Member
    Jun 27, 2011
    439
    Golf TDI/2011
    Kingston, Ontario, Canada
    Window tint, window vent visors, ScanGauge II.
    Get your $500 smacker's back.:annoyed
