Is there a way to test injectors aside from deviations?
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by terpsgeorgia, Jan 6, 2018.
  1. terpsgeorgia
    terpsgeorgia Member
    Nov 26, 2016
    61
    06 Jetta TDI
    Cleveland, Georgia
    Per my other threads, I recently changed the injector seals and after struggling to get the car running, I got it going with reasonable deviations. The car died recently and when I got it home and restarted, the injector deviations were all over the place, way worse than when I checked them a few weeks back. My conclusion is something moved or I have at least one bad injector.... so is there a way to test them?
    I have checked the fuel pump, timing, glow plugs and compression so not sure what is left.
  2. terpsgeorgia
    terpsgeorgia Member
    Nov 26, 2016
    61
    06 Jetta TDI
    Cleveland, Georgia
    So I readjusted, car started and after a minute or so, I was getting good readings on the variations:
    -0.5, -0.3, -0.1, 0.79 (a bit high but given what it has been :) ).
    Let the car warm up, drove around the block and #4 drifted up to about 1.78.
    Then took on street and all things went crazy.
    -2.99, -3.01, -0.64, 2.99
    Cylinder 4 misfire again..
    I am assuming this means my injectors are bad??
