Injection Pump timing
Discussion in 'Biodiesel general' started by 46Chief, May 12, 2011.
  1. 46Chief
    46Chief New Member
    Mar 11, 2011
    8
    VW jetta 2002
    I started using 100% processed fryer oil, and also had a TB change. I have access to a VagCom and am wondering Where I should set timing for the TDI. I've searched this and Fred's site but keep getting distracted and cannot find what I need.
    I know first post isn't an intro, if ya want to know who I am send me a PM. I also needed to post to get access to exclusive content.
    Great site though, definitely the most useful one I know of regarding TDI's.
    23,900
    Open engine. Basic settings and look at the chart for tdi timing. Select ALH engine. Set timing at desired position. Yes, see part 2 of the ALH timing belt writeup for pictures.welcometomyturbodies
  3. 46Chief
    46Chief New Member
    Mar 11, 2011
    8
    VW jetta 2002
    Actually I've been searching to see if it is advantageous to advance or retard the timing in regards to runnig Bio vs dino. I ended up setting it right on the blue line (middle).
    Still sorting out low power issues, timing helped some.
  4. goldstar
    goldstar New Member
    Feb 18, 2011
    20
    Polo 1.4 Tdi 2003
    B100 benefits from advanced timing as it burns slower than D2. At least 3 degrees advance and up to 5 degrees is safe. If you occasionally run D2 stick to three degrees.
  5. 46Chief
    46Chief New Member
    Mar 11, 2011
    8
    VW jetta 2002
    Hasn't seen pump fuel for at least three months. Unfortunately the car is losing power badly, changed the fuel filter, Checked the mech timing, cleaned a bunch of oil from the bottom of the intercooler. The Vagcom doesn't indicate anything bad, no overboost, pressure 12-14lbs, MAF readings looked fine, car doesn't act like it's getting enough boost, fuel or air. guess my woes should be addressed in another forum. Was hoping the Bio might clean some things up run a little better.
    Thanks for the input Goldstar
  6. theodor tymczyna
    theodor tymczyna New Member
    Aug 26, 2011
    passat 2002
    gas flowed head etc...
    bio fuel
    bio is only good with mechanical injection engines because the settings is less critical.
    try and mix diesel with fuel 60diesel 40 bio.
    dont forget we are never sure of the quality of diesel in canada because in the first place .
    i will contact my buddys in the uk on this matter .
    there are tuning houses in the uk who will help to overcome these shortcomings.
    regards theo .t
