IMMO LIGHT TROUBLE 04 Jetta
Discussion in 'Ross Tech VCDS forum' started by Pwinchell, Dec 13, 2011.
  1. Pwinchell
    Pwinchell New Member
    Nov 2, 2011
    20
    2012 Passat TDI SEL/2004 Jetta TDI
    Chesapeake, VA
    So here is my trouble. I baught a new key from VW and had it cut. I figured I would use vag-tacho to get my pin and use vag-com/ross tech to program. Well here is the problem. Vag-Com does not recognize my IMMO system. It has a fault anytime it tries to read it. It will not allow my pin to be excepted or even read my system (just IMMO, other systems it reads). It is the real one not an ebay. I figured I would use Vag-tacho to program new key. Keys programmed fine. Both old and new key work. Problem now is the IMMO light blinks all the time. It doesn't affect anything except it is annoying. Any solution or help to extinguish said light would be appreciated.
