IAT Location?
Discussion in 'VW Mk6 Golf, Jetta, Beetle, Sportwagen TDI forum' started by n8zg, Nov 14, 2016.
  1. n8zg
    n8zg New Member
    Aug 10, 2016
    2012 Jetta TDi
    Navarre, FL
    DPF Delete, BuzzKen Down-pipe & Cat-back, Malone Stage 2 Tune
    Gentlemen -
    2012 Jetta TDi Mk6, 6-speed manual.
    DPF removed
    BuzzKen down-pipe & resonator installed
    Malone 2.5 Tune
    I have a persistent Charge Air Cooler Efficiency fault on my Jetta.
    Clear the fault and unplug VCDS, it comes right back
    If I run the car with VCDS connected, the fault remains off as long as VCDS is active.
    I have cleaned the intercooler inside and out.
    I have found IAT descriptions and locations for just about every other model, but not this one.
    Contents of the fault readout copied below.
    1. Where is the IAT located on the Mk6 Jetta?
    2. IAT part number?
    3. Any other suggestions for correcting this condition?
    neal
    Monday,14,November,2016,19:43:22:60487
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 16.8.3.1 (x64)
    Data version: 20161010 DS267.0
    www.Ross-Tech.com
    Address 01: Engine Labels: 03L-906-022-CBE.clb
    Control Module Part Number: 03L 906 019 EH HW: 03L 907 309 AA
    Component and/or Version: R4 2,0L EDC G000SG 3523
    Software Coding: 0050072
    Work Shop Code: WSC 83983 408 682440
    VCID: 75CF1C2C1C2D71EA9F-8020
    1 Fault Found:
    000618 - Charge Air Cooler
    P026A - 000 - Efficiency Below Threshold - MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 263114 km
    Time Indication: 0
    Date: 2049.14.16
    Time: 16:03:34
    Freeze Frame:
    RPM: 1587 /min
    Speed: 94.0 km/h
    Temperature: 100.8∞C
    Temperature: 25.2∞C
    (no units): 132.6
    Temperature: 84.0∞C
    (no units): 40.0
    Readiness: 1 1 0 0 X
    23,854
    1. Not sure but usually on the intake pipe.
    2. If you find a suspect sensor, look for the part number on it and google it.
    3. Can you use VCDS to read this sensor to determine if it's reading low? It should read slightly higher than ambient.
  3. maintainer
    maintainer New Member
    Jan 24, 2015
    17
    '14 jetta/'06jetta
    ks
    I'm pretty sure the intake temp & intake pressure are two in to one. On the discharge pipe after the charge air cooler.
  4. Keithuk
    6,877
  5. mrblah
    mrblah Member
    Jun 9, 2015
    41
    VW JSW 2014 TDI 6sp
    Montreal, Qc
    Sorry to thread jack but:
    Any info about if the 2014 (so last of this generation of TDIs) had the TSB performed at the assembly?
    Any way to force the dealer to apply this if I've had water in the charge air cooler once?
    Thanks!
