I need some dimensions
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by Toledziak, Feb 17, 2011.
  1. Toledziak
    Toledziak New Member
    Feb 6, 2011
    6
    VW Golf Variant
    Hello. I want to make camshaft pulley puller VW T10052 and I need some dimensions. If anyone have such tool and can measure it, please send me PM.
    23,757
    I can measure it for you later, it is out for rental right now. Which dimensions do you need?
  3. Toledziak
    Feb 6, 2011
    6
    VW Golf Variant
    All dimensions wich are needed to make such puller (diameter, thickness, space between bolts, angle between those bolts, just all dimensions). Can be CAD draw (dxf, dwg). I will be very thankful.
  4. Mikko Rintakuusi
    Mikko Rintakuusi New Member
    Oct 30, 2013
    Golf IV ARL
    Finland
    Hi!
    I need those dimensions too, can you give those for me, thanks? Or even if you have 038109111E toother belt pulley hole dimensions, it helps too!
    I'm going to made DIY tool of T10052 :)
  5. chittychittybangbang
    23,757
    I would give them but they are rented out and I don't have it on hand to measure. If you measure the camshaft pulley bolts, it's exactly that. Just make sure to machine the holes a little larger than your bolts so they can move around a little bit and stay perpendicular to the pulley.
