HVAC Fan noise?
Discussion in 'VW Mk6 Golf, Jetta, Beetle, Sportwagen TDI forum' started by probstk, Oct 19, 2011.
  1. probstk
    probstk Member
    Aug 4, 2011
    77
    2011 Jetta TDI Highline 6sp
    Ottawa, ON
    Dieselgeek Sigma 6 shift kit
    My HVAC fan has an intermittent whine/whistle/bearing screech (?). I don't here it at speed 1, it can start occasionally once speed 2 has been on for a while, is present more often at speed 3 from the start and seems to go away if I go all the way to speed 4 and then back down to 2 or 3.
    I'll have it looked at next time I go for service, but am interested to know if others have experienced this.
  2. golfTDI1
    golfTDI1 Member
    Oct 25, 2010
    308
    2010 VW Golf TDI 6M 4dr
    New York, USA
    see signature
    Had it for one day last year, that was almost 24,000 miles ago, hasn't happened since.
  3. 1120jettatdi
    1120jettatdi New Member
    Apr 2, 2011
    2011 Jetta TDI Sedan
    Fan whistle
    I get the same noise. My car makes the noise whenever the heat is on and the fan is on speed three. If the engine is cold it doesn't make the noise. Only when the engine is warm and blowing hot air. It does this on defrost, floor, or vent setting. I'm not one to complain about interior rattles etc... but I find this highly annoying as I can hear it even when my radio is on. Dealer refuses to fix it saying other cars on the lot make the same noise. When my dog is in the car I can't set the fan on level three because the dog whines and becomes restless.
  4. probstk
    probstk Member
    Aug 4, 2011
    77
    Ottawa, ON
    That's a BS response from the dealer. I'll provide feedback once I've taken mine in. And in the meantime, no canine passengers! :p
  5. probstk
    probstk Member
    Aug 4, 2011
    77
    Ottawa, ON
    Lo and behold, I got the same bull**** answer! "Performs to VW spec", "checked Jetta in showroom and noise is similar". Gonna try again at the next service and will visit a couple of dealers for research in the meantime. Sigh.
  6. freeflyer
    freeflyer Member
    Jun 21, 2010
    48
    Golf Wagon TDI 2010
    i had the same problem and my dealer replaced the fan motor on (extended) warranty. After the exchange the noise was gone. it took 130000km (18month) for the fan motor to fail.
    My dealer is in Vaudreuil, not toooo far from Ottawa...
  7. Ol'Rattler
    Ol'Rattler Well-Known Member
    Apr 24, 2011
    783
    06 TDI Jetta
    Marysvile, WA.
    I know that others with A5's have had fan failures as early as 36K miles. My A5 is at 102K miles and still works and is quiet on all speeds.
    Something I always do is never turn the fan to zero, always at least to 1 because I suspect if the fan sits idle for long periods of time, the commutator oxidizes which will cause noise when you do use it.
    I noticed that after my car sat for about a month when I did the clutch, the fan was slightly noisy for a little while after I got the car back on the road.
    Of course assuming the fan will last longer if it doesn't sit idle is just a theory on my part.
  8. xeno555
    xeno555 Well-Known Member
    Dec 12, 2011
    1,681
    2012 TDI Tech Package 6mt
    Mile High
    The fan is loud on max setting. leaving it on any setting other than max setting, causes it to use the resistor to lower the voltage (thus the fan speed), causing the resistor to burn out prematurely. This was the case for MK1-III. I assume they still use this type of technolgy.
  9. probstk
    probstk Member
    Aug 4, 2011
    77
    Ottawa, ON
    Loud I can handle. The whistling can't be right. If the resistor is gonna burn out, let's hope it does so under warranty!
  10. probstk
    probstk Member
    Aug 4, 2011
    77
    Ottawa, ON
    Update: Asked to have this looked at during 30K service (at another dealership). Same answer: "That's how they all sound, checked some cars on the lot". I still don't buy it.
  11. Mike O
    Mike O Member
    Sep 23, 2011
    38
    Jetta/2006
    frostheater, Colt Stage II cam
    fan noises
    Ok here's my 2 cents. I have had noisy fans on chevys, toyautos, etc, usually an indication of poorly lubed bearings (oil-light, oil impregnated, etc.). the fan in my '06 jetta squeals when cold, like below freezing, so I run on low speed until the noise goes away, then index the speed up as the need arises. Running at full blast when cold will only speed the motor bearings demise....
    Cheers
