How to reset service counter in 2011 vw jetta TDI ?
Discussion in 'VW Mk6 Golf, Jetta, Beetle, Sportwagen TDI forum' started by pawelo007, Jan 12, 2012.
  1. pawelo007
    pawelo007 New Member
    Jan 11, 2012
    vw jetta 2011
    On the instrument cluster, you will see two buttons, one on each side. With the key off, reach in and press/hold the button on the right, keep holding while you turn the key to "on", release that button and press the one on the left. Done and done!
    23,889
    Thank you, I'll add this to the FAQ. Can someone else confirm this before I make it permanent?
  3. vwottawa
    vwottawa Member
    May 11, 2011
    72
    2011 Jetta Sedan TDI DSG Highline
    Ottawa
    VCDS Avail.
    I reset my service counter via VCDS.
    My car has Kessy, so I am not sure if this will work or not.
    pawelo007, does you car have KESSY?
  4. mo_focus
    mo_focus Member
    Oct 27, 2009
    39
    works w kessy as well
  5. Keithuk
    6,910
    I can reset mine in the MFD.
  6. TDIStevestr
    TDIStevestr Member
    Dec 8, 2009
    88
    2011 Golf TDI 4 Door DSG
    Yup on the 11's it is an option in the MFD menu.
  7. vwottawa
    vwottawa Member
    May 11, 2011
    72
    Ottawa
    VCDS Avail.
    Yeah you can reset the counter in the MFD on the GOLF, but you cannot on the '11 Jetta Sedan due to the lowline MFD.
    mofocus, thanks for the reply, on my next oil change, I will try to reset the counter this way instead of with the VCDS.
