how to bypass or temparaily disable the immobilizer
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by 01beetle, Nov 19, 2010.
  1. 01beetle
    01beetle New Member
    Nov 19, 2010
    new beetle/2001
    how do i dissable or bypass the immobilizer in a 01 beetle it shuts down the car after a second so any help would be aprieciated
    Henry bonk likes this.
  2. E. Steven Yankura
    E. Steven Yankura New Member
    May 4, 2011
    2000 beetle
    my 24 hour ban
    Well Sir I tried to post to the forum as you requested. I just couldn't find the active link or...to do it. I appologize I guess after a day of running my repair buis. I am just a bit cross-eyed. I might try again tomorrow. Thanks.
  3. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,763
    Scotland
    PP764's, turbo and mapping
  4. chittychittybangbang
    23,816
    You registered today for the first time, how could I have banned you before? My previous comment was directed at someone else. Seatman included the link, just read the links to the FAQ articles, most of these are common questions that have already been answered.
  5. Olek
    Olek New Member
    May 7, 2011
    Golf/2001
    Olek
    Hi! Friend of mine has a 2001 Golf. Previosly he had a problem with driver side door - it always had a light on the dash saying that it is open. He went to a garage and they disabled something and the light came off. Then a week ago the battery went flat. we recharge it but now immobilazer is not accepting a two originaly fited keys. I have the key reprograming equpment SBB which you connect to OBDII connection and than you programming ECU to accept keys. But it is asking for a pin. That car he had bought 2 years ago and he never knew the code. Is it possible to find the code or bypass it. Could you help me please. :confused:
  6. chittychittybangbang
    23,816
    First the light on dash saying the door is open is probably a faulty door module. It's very common. A microswitch inside the door module goes bad. Either that or the wire harness is cracked in the door hinge area.
    The SKC code should be on the black key tag. If he doesn't have it, take a look at the immobilizer FAQ on how to get it.
  7. Olek
    Olek New Member
    May 7, 2011
    Golf/2001
    Thank you. I may not smart enough but it does not saying how to bypass it and how to get the pin code. It is reffer to FAQ 4.15 but I could not find that charter.
  8. chittychittybangbang
    23,816
  9. dkmensa
    dkmensa New Member
    May 14, 2011
    02 golf
    immobilizer
    My car starts then shuts down. The VCDS has a immobilizer code. The key in car symbol is not lit.
    Please help
  10. applehat
    applehat New Member
    Jun 15, 2011
    2000 New Beetle TDi
    I have this same problem.
  11. Kadi
    Kadi New Member
    Jun 28, 2011
    Jetta 2005
    Ordered a new key and need to get it programmer DIY
  12. sparki234
    sparki234 New Member
    Jun 21, 2011
    27
    v w golf
    Have you tried reading codes I had one before it said engine start blocked by immobilizer it started and then stopped immediately
  13. almir
    almir Member
    Feb 6, 2011
    664
    2005 jetta tdi gls 1.9
    Chicago
    you have nothing to lose, according to el. diagram I see that behind the gauge cluster is green connector, find pins 2 and 17 this wires are related to immobilizer one will be green and one will be black wire, so try cutting one of them before engine dies. If nothing happens, then try starting with one of them cut.
    I don't think that vw would make it so easy to bypass, but you never know. You can always at the end connect wires back to normal. Also if this works, then you could extend wires and install inline switch to disconnect circuit etc.
    Also it would be helpful to know what immobilizer disconnects, I believe that the only way to shut down diesel engine is by blocking fuel delivery. If that is true then we would have to find diagram for fuel pump and injectors and see how to bypass power to them to keep them running even if immobilizer tries to disconnect them. Maybe you can connect voltage tester to certain pin on the pump that is supposed to have voltage with engine running and see if that pin loses voltage when engine dies. If we determine what component loses power or ground when engine dies it is easy to bypass it with a relay or two.
    Maybe it cuts voltage to ECM and then everything dies with it (pump, injectors etc) you will need a good el. diagram with power and ground distributions to fuel pump, fuel pump relay, injectors, and ECM. Then you will know exactly what pins have battery voltage when engine is running so you can have someone hold the voltage meter at each of the mentioned components to see which one loses voltage when engine dies.
  14. enigma_sphinx
    enigma_sphinx New Member
    Jul 23, 2011
    8
    VW Golf 1997
    also want to do the same thing, this might work, thanks
  15. crayonz
    crayonz New Member
    Nov 15, 2011
    Beetle 2001
    Hello guys, I've just got here via Google. My car started but stopped after few seconds. I have unplugged battery reconnected it. Now it's working. Don't know why. Hope it help someone with same problem.
    Still, I want to know how could that happened and how to prevent it from happening again.
    Nice knowing this forum. :)
  16. wildduece2
    wildduece2 New Member
    Jan 23, 2012
    2000 VW Beetle
    Heellllpppp!!!
    I also need help with immobilizer. I have 2000 Beetle and would really like to disable the system either temporarily or permanently. I have good electrical experience and work on vehicles for a living. This is my youngest daughters car and live a significant distance from the VW dealer. Please help if you can. I too am having difficulty navigating the forum. Thanks for any help in advance as it is greatly appreciated.
  17. chittychittybangbang
    23,816
    If you have the SKC number you can input an emergency bypass, see here http://www.myturbodiesel.com/1000q/multi/immo-2-vw-audi.htm Without the SKC you can't do squat with the immobilizer, it's built into the instrument cluster and ecu programming. Only way to remove system is ECU flash, check out kermatdi.com and malonetuning.
  18. The Fezman
    The Fezman Member
    Sep 28, 2011
    38
    2001 new beetle tdi
    i bought a 60$ obd2 immo drive box from ebay, it worked to disable the immo, the lights flash on the dash but a 2ct piece of black tape took care of those, sure beats 200$ for a key or a "chip tune"
  19. tonyflrb
    tonyflrb New Member
    Feb 12, 2012
    VW Beetle 07
    interesting...
    I got an uncut key, so If I buy that, can I make it work then?
    I'll take a look...
  20. nayray16
    nayray16 New Member
    Feb 16, 2012
    2003 VW Passat
    We are having immobiizer problems as well. We have always only had the one key. We had some work done on the car last week and also had to replace the battery. I read if the battery gets low or has to be replaced it couldl trigger the immobilizer. My husband drove it to work the other day no problems but couldn't get home after work as the car wouldn't start. The "car" is flashing on the dash and the read out states "Immob. Active"
    Don't understand all this and hope someone has an easy answer for us.
