Help! CEL codes p0045 and p0047 boost pressure control valve/solenoid
Discussion in 'VW Mk6 Golf, Jetta, Beetle, Sportwagen TDI forum' started by franchize, Aug 24, 2015.
  1. franchize
    franchize New Member
    Aug 24, 2015
    2011 Golf TDI
    Maryland
    New member here hoping someone can help me out! I did a search but didn't find much
    I was driving my 2011 golf tdi (manual trans if that matters) to work this morning when my I got a flashing glowplug light and 'check engine now' and check engine light. restarting the car cleared the glowplug light for anywhere from a few seconds to a few minutes and I made it to work by restarting periodically. Leaving work the flashing glowplug and CEL light were on and restarting no longer helped. I drove home in what I assume is 'limp home mode' with no boost or very little boost. Plugging in my VAGCOM when I got home gave me the following:
    Mode 03: Emission related fault codes
    Address 7E8: 2 Faults Found:
    P0045 - Boost Pressure Control Valve/Solenoid (Bank 1): Open Circuit
    P0047 - Boost Pressure Control Valve/Solenoid (Bank 1): Short to GND
    So it seems like the boost pressure valve/solenoid or the wiring to is the culprit. Is there an easy way for me to check that it's getting correct voltage /resistance to it with a multi-meter? Is this something I could fix/replace on my own? Whats the best place to get a replacement part?
    Really hoping i can get this fixed before a trip this weekend
  2. franchize
    Aug 24, 2015
    2011 Golf TDI
    Maryland
    20150824_212031.jpg ok may have found the problem - a wire leading into the boost control valve has broken and popped out of the plug that attaches the wiring to the valve, although its possible I just broke this messing around with it. Trying to attach pictures.
    Any ideas as to how to fix this? Can i put a drop of hot solder on and try to stick it back together?
  3. xeno555
    xeno555 Well-Known Member
    Dec 12, 2011
    1,684
    2012 TDI Tech Package 6mt
    Mile High
    Pin extraction, then recrimp new pin and reinsert...
  4. Mike321
    Mike321 New Member
    May 8, 2017
    Jetta 2011 TDI
    San Francisco
    Stock
    I signed up to this site to confirm P0045 and P0047 codes were caused by the same problem. Simply looking at the connector yielded no visible defect. I cleared the codes and P0045 would show up immediately before starting the vehicle, so I knew it had to be electrical.
    I unplugged the connector to look for corrosion, the wires looked great. It was only when I unplugged the connector that I noticed the broken wire.
    To the OP, thanks for posting, it helped identify my issue.
    The red/gray stripe wire was clearly broken. I hope this helps others.
