HELP-Broke Fins on Fan Clutch
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by VeeDubTDI, Aug 18, 2012.
  1. VeeDubTDI
    VeeDubTDI New Member
    Jan 13, 2012
    2005 VW Passat TDI
    I'm new and currently working on my car so I don't have to time to do a thorough search. MY question is if I broke 2 fins on the fan clutch while trying to get the fan off, will that cause out of balance issues when I put every thing back together. I discovered that I can get the bottom bolt out through the hole made by the broken fins, but really need to know if I now have to replace the fan clutch or will it be good as is. Thanks for any help.
  2. almir
    almir Member
    Feb 6, 2011
    669
    2005 jetta tdi gls 1.9
    Chicago
    I didn't know that you have fan clutch, can you send picture.
    If you do which I don't think you do, let it spin and see if you see any unusual vibrations, if not then I would let it go.
  3. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,818
    Scotland
    PP764's, turbo and mapping
    Are you talking about the fan blades? if so then yes, you'll need to replace it or more things will break with the vibration.
  4. almir
    almir Member
    Feb 6, 2011
    669
    Chicago
    LOL with 2 blades broken out of 3 not much left to brake even with the vibration. Anyway what would that thing be called? :pukerofl Maybe weedwacker fan.
    if you research this forum you will find post where I replaced complete radiator fan asembly (2 brand new fans and fan shroud) for 118$ and free delivery. I even posted a link to the site.
  5. chittychittybangbang
    23,900
    Yes it'll be out of balance but at this point I'd put it on and fix once the bearing goes bad. Replace now or replace later. For all you know it could last another 5 years.
  6. VeeDubTDI
    Jan 13, 2012
    2005 VW Passat TDI
    I'm not talking about the plastic fan, I am referring to the cast aluminum hub that the fan bolts to, it has the fan pulley behind it.
  7. almir
    almir Member
    Feb 6, 2011
    669
    Chicago
