help 2000 tdi wont start
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by flixpink, Apr 14, 2011.
  1. flixpink
    flixpink New Member
    Apr 14, 2011
    vw
    on my 2000 tdi my car wont start unless i unplug the coolant temp sensor. then car starts up an runs ok but lack full power can any help me with this problem
    23,889
    It sounds like you may have 2 problems. One is the coolant temp sensor being bad. If you unplug it, it turns the glow plug time to maximum but it doesn't sound like that should be a big problem in TX.
    The lacking full power could be many things, I don't want to guess without things like datalogs or error codes, see : http://www.myturbodiesel.com/1000q/multi/low-power-fix-TDI.htm this article for a good start.
  3. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,792
    Scotland
    PP764's, turbo and mapping
    Have you checked for fault codes at all? It might save you chasing around trying to figure stuff out.:)
    welcometomyturbodies
  4. sprstu
    sprstu New Member
    Feb 26, 2011
    9
    81 rabbitTD, 01 Golf TDI, 98 Jetta TDI
    Have you had your timing belt done recently? If so your timing is way off. Unplugging the temp sensor advances your timing to a much greater extreem then the ecu would do alone, it get set into thinking the temp outside is dead frozen. Poor timing will also have an impact on your performance as well.
  5. flixpink
    flixpink New Member
    Apr 14, 2011
    vw
    codes im getting are P1556 , P1144 an P1256
  6. qbics
    qbics New Member
    Apr 16, 2011
    golf mkIV
    P1556 = Motors for central locking, UNLOCK
    P1144 = Central Locking - Opening Motor
    P1256 = Fuel Injector for Cylinder 8 (N86)
