Has anyone used Seafoam in their diesel engine?
Discussion in 'VW Mk3 Jetta, Passat TDI and other/older diesels' started by TDIPete, Apr 16, 2012.
  1. TDIPete
    TDIPete New Member
    Apr 6, 2012
    15
    1999 mk3
    Bondo
    I have used this product for many years on my gas engines (trucks, cars), my two stroke and 4stroke snowmobiles, outboards, etc with great success.
    I have never tried it in my new to me 99 Jetta. I did some research and found this link. I am going to follow the recommendations by pouring Seafoam into my old fuel filter and hot soaking the engine.
    The result on my old gas truck has been amazing and I am assuming it will be good on the diesel also.
    Has anyone tried this?
    Here is the link to Diesel FAQ's and Seafoam.
    http://www.seafoamsales.com/diesel-engine-faqs.html
  2. Pig Man
    Pig Man Member
    Mar 8, 2012
    39
    2012 JSW TDI 6 speed manual
    I hope someone replies to this with experience. I also have a gas truck that I have used Seafoam on a couple times in the past with very good results. I did the "three way" with the gas treatment, oil treatment prior to oil change and the engine choke through the vacuum line. It ran remarkably smoother for quite a long time. I assume that the diesel results will be the same but have may miles to put on my new TDI before considering this.
    I think the one consideration is that Seafoam is 10 to 20% Isopropyl Alcohol. That may be a big no-no for diesel since most fuel additives that are safe seem to tout that the are alcohol free. Anybody have an opinion on that?
  3. TDIPete
    TDIPete New Member
    Apr 6, 2012
    15
    1999 mk3
    Bondo
    Don't know anything about the Isopropyl Alcohol being bad. It does say that Seafoam is safe for diesel engines. Now I am very curious. I think I will do the engine soak anyway....
  4. dezel
    dezel Member
    Jan 5, 2011
    158
    02 jetta tdi leather gls
    Kerma chip & Bosio 520 nozzles
    I cant say it's safe for tdi engines but it did wonders on my toyota sequioa. Ive been fighting 02 sensor codes for over a year even after replacing them and cats. The check engine light would go on and off. So today I got Seaform spray, sprayed it into throttle body, let it soak 5 min. Before I got out of the driveway light was off, runs a lot better. If anyone has a gas vehicle do this simple process first before believing the scanner. Good old ethanol causing problems.
