Golf 06 replace engine+ECU
Discussion in 'Mk5 VW Jetta, Sportwagen, and Audi A3 TDI forum' started by kempi29, May 20, 2012.
  1. kempi29
    kempi29 New Member
    May 20, 2012
    Golf 2006
    I own Golf 5 2.0 TDI, year 2006 which was crashed. I replaced complete engine and ecu with 2008 from the car which was burned inside. Original type motor was BMM, the new one is AZV. The problem is: the engine starts for a second and on the board computer says Immobilizier active! Could I solve the problem myself with vcds diagnostic tool? :dunno Thanks for your time and your help.
  2. Keithuk
    6,905
    No VCDS will only fix your problem if you have the SKC. To obtain the SKC you need VAG TACHO or one of the other devices like VAG Commander 1.4.
  3. kempi29
    kempi29 New Member
    May 20, 2012
    Golf 2006
    Thanks. Maybe you know what version of vag tacho would be enough, 3.01?
