Glow Plugs
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by foxden, Apr 11, 2012.
  1. foxden
    foxden New Member
    Dec 23, 2010
    4
    2001/2003 Jetta TDI
    My 2003 Jetta Wagon with 107,000 miles has a code P0671 #1 glow plug. Doing some reading on here I find it could be the plug or the harness. I'm going to OHM the plugs and also check the harness. If the plug is bad, what should I be careful of when replacing. I plan on replacing all the plugs.
    Thanks
  2. stubb's
    stubb's New Member
    Apr 11, 2012
    4
    mk4 golf tdi
    Yes, replace all the plugs. Just be careful they can strip out easily. If the code still comes up replace the harness. That was my problem. I made my own harness to save some money. Worked great. It's been over a year with no more code. :D
    Eric
  3. shuswap
    shuswap Member
    Dec 12, 2010
    186
    2005 Golf TDI auto
    Also, if you switch the plugs to a different hole then you can determine if it's the plug or the harness. IE....did the code change to a different cylinder.
    Be very careful with the plug extraction....they are alum, as is the head. I worked mine back and forth to free them up.
    Put a little non-seize on the threads before installing the new plugs and remember that they are torqued to a VERY low value....sorry I don't have the number handy, but a search should provide an answer for you.
