engine mount instructions
Discussion in 'VW Mk4 Jetta, Golf, New Beetle, Passat TDI forum' started by almir, Apr 16, 2012.
  1. almir
    almir Member
    Feb 6, 2011
    669
    2005 jetta tdi gls 1.9
    Chicago
    Hi all,
    any instructions on engine mount inspection and replacing?
    I notice that when I push and pull the engine on the driver's side I can make it to shake bit, how many mounts are on the driver's side of the engine, and which mount usually goes bad first on this engines?
    Thanks for any advices, 2005 1.9 TDI (BEW) Jetta
  2. Seatman
    Seatman Well-Known Member
    Jul 9, 2010
    5,815
    Scotland
    PP764's, turbo and mapping
    One on the end of the gear box and the dogbone underneath but that's not the drivers side, your steering wheel just happens to be on the wrong side :D
  3. chittychittybangbang
    23,900
    It should shake a little bit...the engine hangs from 2 mounts and the dogbone mount holds it in place. No instructions but if you look at the timing belt replacement, transmission removal, and dogbone mount replacement article the instructions are scattered in those articles.
